ᐅ Installing a Sink Faucet on the Countertop?
Created on: 17 Sep 2023 18:58
Janna12
Janna12
17 Sep 2023 18:58
For our new kitchen, we are considering whether to mount the faucet on the sink or on the countertop (not real wood). What are the advantages and disadvantages of each option?
Thank you in advance for your answers!
X
xMisterDx
17 Sep 2023 23:26
Advantage? Probably none. The further the faucet is installed from the sink, the more inconvenient it is in everyday use... or does it actually end up closer? If so, then it is an advantage.
Disadvantages... with proper sealing of the countertop, probably none.
Why do you want to do this?
Especially in the kitchen, always keep in mind:
Function absolutely comes before appearance and design.
motorradsilke
18 Sep 2023 07:52
It also depends on what kind of sink you have. There are sinks with very narrow edges or those that are installed under the countertop. In those cases, the question doesn’t really arise. If you have a sink with only one basin, the faucet is best placed in the middle, behind the basin. If you have two basins, it’s probably better to position the faucet centrally between them.
Otherwise, I don’t see any advantages or disadvantages.
hanghaus2023
18 Sep 2023 08:38
Usually, this is not an issue since the sink already has a hole for it.
Make sure to seal it well on the countertop.
After 15 years, I replaced the faucet with one that has a pull-out spray. Best decision.
X
xMisterDx
18 Sep 2023 08:56
Absolutely. For the kitchen faucet, only flexible hoses with a spray function should be used. Fixed faucets belong on the bathroom sink.
motorradsilke
18 Sep 2023 09:00
xMisterDx schrieb:
Absolutely. Kitchen faucets should always have a flexible hose and spray function. Fixed faucets are more suitable for bathroom sinks.
Even there, a faucet with a spray function can be useful for occasional hair washing 😉.
