ᐅ Moisture Sealing of the Concrete Slab
Created on: 3 Feb 2020 13:01
trksglm
for better moisture protection, the waterproof membrane will then be extended up along the exterior walls, similar to a basin.
When I mentioned this to the builder, they responded:
the waterproof membrane will NOT be extended up the exterior wall.
The installation complies with the requirements of the DIN standard.
How necessary is this? Should I insist on having the membrane extended up the wall?
Corner with white tiled walls, dark, dirty floor and moisture at the base.
Corner: white wall meets gray tiles, dark floor; dust, stains and chipping at the base.
Empty room with white wall blocks and dark gray floor.
Baufie
6 Feb 2020 19:46
In our case, only the basement floor slab is made of waterproof concrete. The walls are standard cast-in-place concrete and are then constructed as a black tank waterproofing system.
Bookstar
6 Feb 2020 20:13
Then you need to seal it, and you have done everything correctly!
Z
Zaba12
6 Feb 2020 20:18
Baufie schrieb:
In our case, only the basement floor slab is made of waterproof concrete. The walls are standard cast-in-place concrete and are constructed as a black tank waterproofing system.
Cast-in-place concrete refers to the construction method of the basement. Even waterproof steel fiber reinforced concrete with a thickness of 25cm (10 inches) is considered cast-in-place concrete.
Baufie
6 Feb 2020 20:34
Bookstar schrieb:
Then you need to seal it, and you did everything correctly!
I know.
PyneBite
29 Apr 2020 21:53
Nordlys schrieb:
Oh, trust me, a C20/25 concrete slab is not waterproof. Water will seep through from underneath or the sides. That’s why a barrier is necessary.
Hi,
quick question: If the soil is very clay-heavy (almost no drainage), does it make sense to use waterproof concrete for the foundation slab, or is a waterproof membrane completely sufficient?
I’m really worried about moisture damage.
