ᐅ Moisture in the Roller Shutter Box – Troubleshooting Causes
Created on: 2 Jun 2024 23:21
wusti_recher
wusti_recher
2 Jun 2024 23:21
Hello dear experts,
my wife and I have purchased a house built in 2000. The building description is attached.
On the weather-exposed side of the house, some of the roller shutters (not all) show moisture damage, see pictures. The plaster/cladding of the roller shutter box is porous and can be damaged with a finger.
A friend who is a building inspector did not find any damage on the outside. He suspects it developed due to convection over 24 years and only became this severe because no one ever took care of it. The previous owner was not a craftsman. I am surprised that such severe damage is present above the roller shutter box, even though the expanded polystyrene (EPS) insulation appears intact and continuous. Perhaps the moisture also comes from the windowsill above?
What is your assessment of the cause of the damage?
My amateur approach would be to:
  • scrape off the porous “plaster” and replaster with a moisture-resistant mortar
  • replace the cover panel facing the interior (which material?),
  • seal the joints between the side parts and the expanded polystyrene (EPS) with silicone
and tape the seams of the inspection cover with sealing tape.
Best regards from Wuppertal.
Exterior wall of a house with rough plaster, window with broken pane at the top, roller shutter at the bottom.
Window with white frame on yellow wall; cracks, moisture, hole at the top, cable duct on the right.
Close-up of a plastered wall area with cracked, flaking plaster and mold spores
Close-up of a window frame with roller shutter guide and glass window, yellow painted wall in the background
Close-up of a silver metal rail with black bracket on a door or window guide.
Lower door threshold with rusty metal guide, screws and crumbling plaster.
