ᐅ Moisture issue with interior plaster after installing external insulation using ventilated rainscreen system
Created on: 5 Jun 2016 11:28
StefanPoe
we are currently working on a rough construction site schedule and have come across a question.
We plan to insulate the exterior facade with 25cm (10 inches) ETICS (classic polystyrene boards) immediately after completing the exterior walls, roof, and window installation. (The advantage is that we only need to set up scaffolding once, and we avoid issues with drying times during winter.)
Now to my question:
If we plaster the interior walls afterward, will the moisture introduced during this process still be able to escape effectively if the external thermal insulation is already installed on the exterior wall? The same applies to the screed applied afterward.
Thank you very much for your information and answers.
Stefan
Now to my question:
Stefan
Peanuts7414 Jun 2016 10:01Exactly, I don’t understand rushing the construction either; good things take time...
Sebastian7914 Jun 2016 10:06That is why we have also been building for 13 months
Peanuts7414 Jun 2016 10:11We also took about 15 months from groundworks to moving in, although we did quite a lot of the work ourselves...
Sebastian7914 Jun 2016 10:12Exactly, same here – moving day is Saturday. But first, just putting in clothes, then spending the next 1-2 weeks unpacking and organizing.
Sebastian79 schrieb:
Allow 1-2 weeks for moving in and tidying upHaha, that was good...
You should actually expect more like 1-2 months.
Sebastian7914 Jun 2016 10:42No, it will take even longer – but we should be able to move in within 1-2 weeks.
