We like two-panel windows (without a central mullion). They will probably be made of uPVC. Do such windows make sense at a width of 100 cm (40 inches)? Or are the panels then too narrow and impractical? The same question applies to the patio door: it will be 113 cm (45 inches) wide. Is it possible to have two panels here, or does everything become too narrow?
Best regards, Steffi33
Christian NW12 Nov 2017 12:39Doc.Schnaggls schrieb:
we have patio doors (triple-glazed) measuring 2.34 m by 1.17 m (7 ft 8 in by 3 ft 10 in). Therefore, a single-leaf element should also be easily possible for you without issues related to the weight of the unit.
Based on the passage width alone, I wouldn’t choose a patio door narrower than 80 cm (31 inches).
Dirk Good morning,
May I briefly follow up on your response and ask about your experience with your 117 cm (46 inches) wide patio doors?
Are they still performing well, or have you noticed any issues over the years like sagging, loose hinges, etc.?
Have the doors needed frequent adjustments?
I would also be interested to know your manufacturer.
Thank you
