ᐅ Minimum width for a double-leaf window or patio door?
Created on: 9 Nov 2015 22:50
Steffi33
We like two-panel windows (without a central mullion). They will probably be made of uPVC. Do such windows make sense at a width of 100 cm (40 inches)? Or are the panels then too narrow and impractical? The same question applies to the patio door: it will be 113 cm (45 inches) wide. Is it possible to have two panels here, or does everything become too narrow?
Best regards, Steffi33
Steffi33
19 Nov 2015 12:04
Thanks to everyone for your input.
Thanks to Michael... Yes, that helps me a lot.
@ Musketier
Michael says he only has to open the second sash in exceptional cases. In everyday use, one sash is enough.
My conclusion: I have the following impression... those who have a wide sash cannot imagine it being narrower (a hypothetical assumption). But when someone actually has a narrower door, it works very well.
Musketier19 Nov 2015 12:45
I’m not sure if it’s really necessary to restrict yourself so much when building a new house.
As someone who isn’t particularly broad-shouldered and works in an office, I estimate my shoulder width to be about 50–55 cm (20–22 inches). When walking, people usually don’t keep their arms completely straight down, so a body width of around 60 cm (24 inches) is reasonable to consider. For those with broader shoulders than me, passing through a doorway might mean turning sideways (unless the stomach isn’t protruding) or having to open the second door leaf. It’s no coincidence that interior doors have a certain standard width.
Steffi33
19 Nov 2015 14:13
Michael doesn't sound like he has to force himself into a tight space.
So... now I had the idea to try this at our patio door.. see picture.. there is a folding ruler spread out to 60cm (24 inches) at the bottom. I noticed that we usually never open our door wider than 60cm (24 inches), because there is always a heavy armchair in the way (on the right in the picture). If you want to open it wider, you always have to move the armchair, which we rarely do. Often we wedge our patio door against the armchair so it doesn't close.. And that works very well for us.
Rear view of a person in the entrance area in front of an open glass door to the garden
miho
21 Nov 2015 09:45
Hello Steffi,
Good idea to give that a try. You should let your husband do it as well.
You probably wouldn’t have any issues with our doors. In the end, it has to work for you, not for theoretical people with bodybuilder backs and wide doors.
Of course, you can always plan for the maximum, but that also leads to maximum costs. The trick is to make compromises in the right places. Your window widths seem to be a good example of that.
Michael
21 Nov 2015 10:31
Hello Steffi, that’s a great idea of yours to share a picture on the topic from you.
Best regards, Yvonne (who occasionally enjoys the two doors that open a full two meters (6.5 feet) wide, because then the garden flows into the house )
Saruss
21 Nov 2015 13:13
That also depends on personal habits. We have a double-leaf door with each leaf about 80cm (31.5 inches) wide, but we only use one of the leaves. However, we have house cats, so the door is currently being closed repeatedly. So far, all people and objects have passed through a single leaf without any issues.
