ᐅ Minimum width for a double-leaf window or patio door?
Created on: 9 Nov 2015 22:50
Steffi33
We like two-panel windows (without a central mullion). They will probably be made of uPVC. Do such windows make sense at a width of 100 cm (40 inches)? Or are the panels then too narrow and impractical? The same question applies to the patio door: it will be 113 cm (45 inches) wide. Is it possible to have two panels here, or does everything become too narrow?
Best regards, Steffi33
Musketier11 Nov 2015 17:54
6 panes on the inside and 6 on the outside = 12 panes to be plastered x 4 corners = 48 corners
Steffi33
11 Nov 2015 17:59
That's right...! I always clean only from the inside.
That works well as a brain teaser...
Musketier11 Nov 2015 18:13
In our new house, despite having windows without muntins, we have now switched to a professional window cleaner. He finished cleaning the entire house in 50 minutes, whereas doing it yourself would have taken a whole day of hard work.
Bauexperte
11 Nov 2015 18:16
Musketier schrieb:
It's up to you. We had one vertical and two horizontal muntins, so each window had 48 corners.
Hmm ... it’s quite late and it’s been a long day. But based on your information, I count a maximum of 32 corners; total inside and outside.
Regards, Bauexperte
Bauexperte
11 Nov 2015 18:19
Argh – just read it now; the cross braces divide the vertical post ops:
Regards, Bauexperte
Bauexperte
11 Nov 2015 18:20
Musketier schrieb:
... switched to a professional window cleaner. He was done with the entire house in 50 minutes, which would have taken me a whole day to do myself.
Even the inside? I only know “fast” window cleaners who skip the inside of the frames… that’s so far stopped me from hiring one.
Best regards, Bauexperte
