Does the 3m (10 feet) minimum distance apply from the foundation slab? I would like to make the foundation slab 10cm (4 inches) larger and add facing bricks afterwards, while maintaining a 3m (10 feet) distance from the building wall, and later reduce the distance to 2.90m (9.5 feet) with the brick facing according to clause 14 of the NRW building regulations. Is it possible that the 10cm (4 inches) overhang of the foundation slab does not count towards the property boundary? Regards, Simon
nordanney7 Sep 2015 16:31I’m more wondering: How expensive and complex will that be? Credibility is another matter entirely (although I’m just a layperson myself).
Why not simply glue clinker brick slips directly and stay within the building permit / planning permission area?
SimonMoers7 Sep 2015 16:51Yes, that is an alternative, but I am not so sure if the thin facing bricks look that good...
Hello Simon,
I think you might be overcomplicating things. Additional thermal insulation is generally allowed, but for a new build this approach is usually not taken. If you still plan to do it, though, it’s not a problem; the foundation slab is not considered an external dimension.
Dirk Grafe
Dirk Grafe
nordanney7 Sep 2015 16:59SimonMoers schrieb:
Yes, that is an alternative, but I'm not really sure if the thin bricks look that good... Have you seen any new houses with thin bricks? There is no noticeable difference compared to facing bricks.
Bauexperte7 Sep 2015 23:42Hello Dirk,
Regards, Bauexperte
Dirk Grafe schrieb:Learned something new again; I thought a protruding foundation slab would also count as the furthest projecting component.
but that is not a problem, the foundation slab is not counted as an exterior dimension.
Regards, Bauexperte
