Bruddler-18 Dec 2012 17:40Hello, a simple question: can I use standard mineral wool for the base insulation behind the facing brick, or is there any reason not to?
MODERATOR9 Dec 2012 19:14For this detail, you should use so-called perimeter insulation, which refers to insulation materials designed for use in "components in contact with the ground" and that handle moisture well. Mineral wool can become wet and then lose its insulating properties and structural stability.
Bruddler-112 Dec 2012 17:10Perimeter insulation? I’ve never heard of it before, good thing I asked—I would have otherwise used regular mineral wool. Perimeter insulation is probably available at hardware stores, right?
MODERATOR12 Dec 2012 17:33Yes, exactly, perimeter insulation (usually rigid foam boards made of PU or EPS) can be found at building supply stores.
Bruddler schrieb:
Perimeter insulation? Never heard of it, good thing I asked, otherwise I would have used regular mineral wool. You can probably get perimeter insulation at a hardware store, right?Yes, I also bought it at a specialized building supply store. I used EPS, which is expanded polystyrene rigid foam. It provides good insulation for the base area of the building. However, installing this insulation is not so easy. That’s why I consulted a professional.
