HilfeHilfe28 Jun 2015 22:38Hello,
Our electrician is letting us down a bit. The following dimmer was installed:
Merten MEG5131-0000
Can I now safely buy LED bulbs, or is that not possible? I don’t want to spend money for nothing. So far, we have been using halogen bulbs...
Merten MEG5131-0000
We don’t have a turn function, we have a tilt function... standard from Merten.
Our electrician frowned when he heard about using LEDs combined with a dimmer.
The typical dimmer from the building contractor/electrician is usually not LED-compatible; it seems you would have needed to specify or order one separately, based on how he frowned.
However, it must be noted that a) the lamp itself and b) the LED bulb need to be dimmable.
We made sure of that and can only dim in two stages. But that’s no problem 😉 The lamp is almost always off anyway.
HilfeHilfe29 Jun 2015 13:47OK
I have a basic question. I have a standard switch. Can I simply replace halogen lights with LED lights?
HilfeHilfe29 Jun 2015 17:09My electrician says that I need to install a transformer everywhere.
