ScubaDiver24 Jan 2022 12:24Hello everyone,
We are currently installing the flooring in our new build. We have chosen luxury vinyl plank flooring. Now we need to decide on the baseboards. We were strongly advised against using MDF baseboards because leftover moisture can cause mold. Apparently, this is not an issue with solid wood baseboards.
Do you have any experience with this? Is it really best to avoid MDF baseboards in new constructions?
Thank you very much and best regards
I haven’t heard this explicitly before, but it sounds plausible since MDF tends to act as a sealant. That means if there is still a lot of moisture in the walls, it would be harder for it to escape at the places where the baseboards are installed.
Solid wood would be more breathable, allowing the moisture to dissipate. However, this only applies if the solid wood is untreated. Once you paint or seal the wood baseboards, it creates a barrier as well. Therefore, you might not want to install baseboards during the first year.
Overall, I doubt that in a new build, where floor coverings and drywall are already being installed, there would still be enough moisture to cause mold problems specifically around the baseboards.
Benutzer20024 Jan 2022 12:55That doesn’t matter at all. Do whatever you prefer. Mold will not be an issue.
My daughter used veneered MDF in her new build. Every time it’s wiped, it gets scratches that don’t improve the look of these trims. She regrets not considering this small detail and would have preferred solid wood (painted white). That’s what we ultimately chose, and since I’ve also had experience with “cheap” veneered materials, I don’t see their justification. Alternatively, if the color fits: solid oak or beech, oiled or glazed (that was our first idea, but it wouldn’t have matched the color as well).
