ᐅ Maximum power capacity for kitchen appliances?
Created on: 18 Jan 2023 16:41
Pianist
Good day!
This isn’t directly about house construction, but since many electrical experts read this forum: What would be a reasonable upper limit for an occasionally used appliance in the kitchen? A kettle typically has about 2 kW, and I believe that’s close to the maximum because it already draws nearly 9 A. Standard household outlets are rated for a continuous load of 10 A, as far as I know. If I were to connect a crepe maker with 3 kW, it would draw around 13 A, possibly for half an hour. That’s too much, right? So when choosing a crepe maker, it’s best to go for one with a power rating around 2 kW, isn’t it?
Matthias
X
xMisterDx
21 Jan 2023 01:54
VW limits the charging power for its ID.x models to 2.3 kW, which exactly corresponds to the 10 A that a standard Schuko socket must be able to carry continuously according to regulations. BMW also specifies around 2.3 kW charging power for a Schuko socket...
I’m not really concerned about what BYD or Schisselaweng do; if they draw 16 A, they can go ahead and risk actually setting the house on fire.
German manufacturers limit their charging power on a single-phase Schuko to 2.3 kW. And there is a good reason for that...
MayrCh
21 Jan 2023 09:42
xMisterDx schrieb:
VW limits the charging power for its ID.x models on a standard household socket (Schuko) to 2.3 kW, which corresponds exactly to 10A
VW does not limit the current to 10A in the cars themselves. It is true that the charging bricks included with the current ID3 deliver 10A, but the car can accept AC charging at 16A per phase. The e-Up came or comes with a 13A ICCB (in-cable control box) and uses that current, as did the first edition of the ID3 during ramp-up phases. There is also the ID Charger Travel, which can provide up to 16A per phase.
