ᐅ Bricking Up a Window with Calcium Silicate Bricks and Insulation – Explanation of Cavity, U-Value, and Condensation
Created on: 26 Dec 2025 23:34
Pascal2201P
Pascal220126 Dec 2025 23:34Good evening everyone,
I am currently renovating a house from 1973 – the exterior walls are built with 30 cm (12 inches) aerated concrete blocks, and 14 cm (5.5 inches) polystyrene insulation (WLG035) will be installed. I want to block up a few windows beforehand and still have plenty of clean 11.5 cm (4.5 inches) calcium silicate hollow bricks left from the demolition work.
Is there any reason not to fill the window openings with two rows of calcium silicate bricks and insulate the 7 cm (2.75 inches) gap in the middle? That should roughly equalize the U-values.
Could you also comment on my father-in-law’s statement: “just leave an air gap, that insulates too”? Wouldn’t that cause condensation problems in that cavity?
Thanks and best regards
Pascal
Pascal
nordanney27 Dec 2025 08:21If you insulate from the outside, you can do whatever you want.
