ᐅ Masonry using Ytong blocks, 24 cm or 30 cm thick, for a single-family house?
Created on: 20 Aug 2019 20:45
Ruska
Hello building experts,
It looks like construction can start soon. I was convinced by the regional TuC partner regarding the overall concept because of the monolithic construction method.
In the "basic package," the masonry is made from 24cm (9.5 inches) Ytong blocks. Does anyone have practical experience with thermal and sound insulation? The residential location is very quiet, traffic-calmed, and has almost no through traffic.
Alternatively, I am considering a build with 30cm (12 inches) blocks; I still need to find out the additional cost.
Ruska
Ruska
24cm Ytong as an exterior wall? Considering that at specific points, for external electrical boxes and water pipes (shower, bathtub, etc.), 5cm (2 inches) will be chiseled out, that would leave only 19cm (7.5 inches) remaining.
There are also some plumbing companies that, without hesitation, install the supply and exhaust air ducts of the controlled residential ventilation system inside the exterior wall, which means that with a 24cm (9.5 inches) wall, there might only be 5cm (2 inches) left.
Also, the increase from 24cm (9.5 inches) to 30cm (12 inches) is crazy expensive (10,000 euros), which can’t be right since the actual difference should be limited!
Stubai83 schrieb:
We built with 42.5cm (17 inches) Ytong blocks and are satisfied with them. Of course, you can’t expect much in terms of sound insulation.
Regards Is that a typo, or do you really mean 42.5cm (17 inches)? I wouldn’t have expected compromises regarding sound insulation there.
Zaba12 schrieb:
The jump from 24cm (9.5 inches) to 30cm (12 inches) is crazy (10,000€), that can’t be right, since the actual difference is limited! At least with TuC, the thicker block also comes with better roof insulation.
So, we also built our garage with monolithic 24 ytong blocks... but for a single-family house? My minimum would be 36 cm (14 inches)... We ourselves have 17.5 cm (7 inches) calcium silicate blocks (20 / 2.0) plus 14 cm (5.5 inches) external thermal insulation composite system (ETICS) with a lambda value of 0.035. I’m not sure about the energy saving regulation standard, as we didn’t build according to any particular standard. In any case, we are satisfied and have no issues with sound insulation...
24 cm (9.5 inches) really sounds like the "cheapest" option...
Basti2709 schrieb:
I’m not sure about the Energy Saving Ordinance standard, since we didn’t build according to any specific standard.You must have built (at least) according to the Energy Saving Ordinance, as that is what must be complied with.Similar topics
