Philipp11223 Jun 2021 10:06Hello!
We have purchased a house and are currently planning the renovation. We would like to install underfloor heating, but embedding it in the screed is not an option.
We are considering a dry system retrofit, as it seems to be the simplest solution at first glance. However, we are unsure which manufacturer to choose.
Does anyone have experience with the different manufacturers, or maybe personal experience they could share with us?
Thank you very much in advance for your answers!
Philipp
Philipp
nordanney23 Jun 2021 11:12Philipp112 schrieb:
We would like to retrofit underfloor heating, but installing it in the screed is not an option.Why not? I just installed underfloor heating in the screed myself. Then new screed on top. Total build-up height 65mm (2.6 inches). Philipp112 schrieb:
We would prefer to retrofit a dry system, as it seems to be the simplest solution at first glance. However, we don’t know which manufacturer to choose.
Does anyone have experience with different manufacturers or personal insights they could share with us? I looked into it but concluded that a conventional system is better for me. Build-up height and cost were the deciding factors for choosing a conventional underfloor heating system.P
Philipp11223 Jun 2021 17:52nordanney schrieb:
Why? I just installed underfloor heating in the living room myself. Then a new screed on top. Total buildup height 65mm (2.6 inches). The problem is that this is a two-family house, and the apartments are already nearly two centimeters (0.8 inches) higher than the stairwell. If I add another 65mm (2.6 inches) of screed in the apartments now, there will be almost an 8cm (3.1 inches) difference in height compared to the stairwell. We didn’t want to renovate the stairwell for the time being, as it is still fairly new.
May I ask how much you paid per square meter (square foot) approximately?
Regards
Philipp
What matters more is whether the ceiling height allows for adding another layer inside the apartment. I would actually find an 8 cm (3 inch) step almost more practical than a 2 cm (1 inch) step.
However, it also needs to be checked if the structural engineering can support the additional weight.
Alternatively, the old screed could be removed.
nordanney23 Jun 2021 23:29Philipp112 schrieb:
The problem is that it’s a two-family house, and the apartments are already nearly two centimeters higher than the stairwell. If I now add another 65mm (2.6 inches) of screed in the apartments, I’ll have almost an 8cm (3.1 inches) height difference to the stairwell. Hmm – how about removing the old screed first? There must be something applied on the raw subfloor.
Philipp112 schrieb:
May I ask approximately how much the cost per square meter was for you? For 120sqm (1,292 sq ft) I installed about 1,600m (5,250 ft) of underfloor heating pipes (MSV pipes) with a total of 15 circuits. Beneath the underfloor heating there is 2cm (0.8 inches) of WLG22/23 PUR insulation (which is fine, since my basement ceiling will also be insulated). The screed is a traditional cement-based screed including steel fibers (which don’t really add much) and an accelerator (the screed was ready for covering after just over one week).
Partly DIY, partly contracted out.
Costs including gutting and disposal amounted to about €70 per sqm – so from “removing the floor” up to the point “ready for the tile and parquet installers.” Oh, and almost half of the costs went into gutting (which also included demolishing two bathrooms and one wall).
nordanney schrieb:
Accelerator (the screed was ready for covering after just over one week)May I ask about the additional cost here?Similar topics
