ᐅ Malm Nightstand Stains Caused by Sunlight – How to Remove Them?
Created on: 31 Jul 2020 21:27
U
USBESARHello everyone,
I have an issue with my Malm bedside table from Ikea. I noticed some stains have appeared on the surface, which seem to be caused by sunlight exposure. The wood or veneer looks faded or discolored in certain areas, even though I clean it daily and do not leave any liquids on it. I suspect these stains develop due to contact with UV light, which can happen with veneered or coated furniture.
My question is: How can I effectively and gently remove such stains from the Malm bedside table without causing further damage to the surface? Are there any proven methods to restore fading or at least conceal the stains?
I would really appreciate any helpful tips or specific products, as I would like to keep the piece of furniture.
Thank you in advance!
Stains caused by sunlight on a Malm nightstand are usually due to UV-related fading of the melamine coating or veneer quality. Removing these stains is challenging because the color change typically occurs structurally within the material.
Some practical approaches:
1. Cleaning: First, clean the surface thoroughly with a mild detergent to remove dirt.
2. Refreshing: Special furniture care products or waxes for melamine can enhance the shine and even out minor color differences.
3. Protection: Prevent future damage by shielding the nightstand from direct sunlight; UV-protective films or blinds can help.
4. Repair: For more severe discoloration, unofficial touch-up pens or repair kits matched to the color can be used.
Complete removal of the stains is usually not possible because the material is damaged more deeply.
Hi USBESAR,
I would like to add something: The issue with sunspots on the Malm nightstand is actually caused by the fading of the white melamine coating. Melamine films are not completely UV-resistant and act as a thin protective layer.
That is correct, which means conventional cleaners have no effect on the actual color loss. You could try using very fine-grit sandpaper to gently remove surface discoloration, but this should be done carefully and only tested on inconspicuous areas.
If the nightstand is painted (which is rare for Malm models), you can touch it up by repainting with special lacquer.
Another option is creative camouflage — using a furniture touch-up pen or self-adhesive film, although this might not be visually ideal for everyone.
If you want to dig a bit deeper or add extra protection: there are UV protection films for windows that can prevent further fading of the furniture.
I hope this helps a bit, even if there’s no perfect solution 🙂
Lotizar schrieb:
The color change usually occurs structurally within the material itself.
Hello USBESAR,
I’m very familiar with this issue because the same thing happened to my Malm nightstand a while ago. It’s kind of sad when your favorite piece of furniture shows visible damage from the sun.
I used special furniture waxes that helped to even out the affected areas a bit. It doesn’t restore the missing whiteness, but the nightstand looks more uniform afterward. Even though you can’t get rid of the sun damage, it does help somewhat.
Sometimes you just have to accept that furniture won’t always look like new forever. I still found it acceptable because I was able to disguise it a little. If you want, I can share the products I used.
Another option is to reposition the nightstand or use a nice table runner to cover the damaged spots. Just a thought. I hope you find a good solution!
USBESAR schrieb:
Stains have appeared, which apparently resulted from sun exposure
V
valentino1 Aug 2020 15:36From a technical perspective: The melamine coating on Malm furniture is designed for light use and scratch resistance, but it is not UV-resistant. Fading caused by sunlight exposure is an irreversible chemical change to the surface.
I can confirm this. The best prevention is to minimize the furniture's exposure to direct sunlight. Repair is only possible for cosmetic purposes, for example using furniture touch-up markers or stickers.
For a permanent solution, the damaged surface would need to be sanded down and resealed, which is practically not feasible with melamine coatings. Therefore, replacement is often recommended if the appearance is severely affected.
