ᐅ Malm nightstand plastic feet often break – what alternatives are available?
Created on: 14 Feb 2015 09:37
Pezar64
Pezar64
14 Feb 2015 09:37
I have a problem with the plastic feet of my IKEA Malm nightstand breaking quite quickly. They don’t seem to be designed to support the weight and stress properly, which is a bit disappointing since I actually like the model a lot. Plastic isn’t always a bad choice, but in this case, an alternative might make more sense.
Does anyone have experience with more durable alternatives to the standard plastic feet? Are there replacement parts made of metal or wood that fit well and are genuinely longer lasting? I’m specifically looking for something easy to install that simply replaces the original foot without having to rebuild the entire nightstand or compromising its style.
I’d appreciate any recommendations or tips because the breaking plastic feet are really frustrating, especially when you need to move the nightstand often.
Best regards!
TISON
14 Feb 2015 10:12
Pezar64 schrieb:
The plastic feet of my Malm nightstand break easily
Well, if you rely on plastic at IKEA, you shouldn’t expect miracles when it comes to durability. Honestly, I think the hype around the Malm nightstand is a bit overblown. Sure, it’s affordable and stylish, but the materials tell a clear story. Metal legs are naturally more durable, but do they really fit the minimalist design? Or maybe you just need to choose different furniture if quality is your priority. I think people often don’t question enough why these feet break so often. Maybe the design isn’t intended for heavy load.
LOPAU
14 Feb 2015 11:05
I had exactly the same problem and can recommend a metal version that you can find at hardware stores. It is important to pay attention to the drill holes and dimensions. Some users have attached alternative furniture feet made of chrome-plated steel or stainless steel and had good experiences with them. Another option is to add felt pads to plastic feet to reduce movement and breakage.
Additionally, it should be considered that frequent moving of the bedside table on hard floors puts more stress on the feet. Using a rug underneath can also help extend their lifespan.
Parmin
14 Feb 2015 13:26
TISON schrieb:
maybe the design isn’t intended for heavier loads
That could indeed be a key point. IKEA certainly aims for cost efficiency, and the design reflects that. However, I would not rule out the possibility of finding alternative solutions. From my perspective, it’s important to first analyze the load patterns: How much weight rests on the legs, and how often are they moved? Without this data, it’s difficult to assess whether more robust legs are just a design feature or a functional improvement.
Are there any user experiences regarding weight limits or frequency of use? That could help clarify the discussion.
MOBALI
14 Feb 2015 14:49
Stainless steel feet from the hardware store are sturdy and usually look suitable. Pre-drill and use appropriate screws.
Silicone or rubber pads between the foot and the floor reduce abrasion and pressure.
jakob70
15 Feb 2015 07:03
I simply placed small wooden blocks under the plastic feet of my Malm nightstand. This reduces the load on the original feet, preventing them from breaking so quickly. It's inexpensive and has been working without any issues for over a year.
