ᐅ The Malm nightstand wobbles slightly – is it worth repairing?
Created on: 13 Jan 2022 18:47
MulubuHello everyone,
I have a Malm bedside table from Ikea that wobbles slightly—only a little when you bump into it or lean on the edge. Overall, it’s still quite stable, but it bothers me because I’m worried the problem might get worse. Now I’m wondering if it even makes sense to fix this minor wobble or just leave it as is.
I understand that furniture like this, due to its simple construction and materials, won’t remain perfectly stable forever, but I’m curious whether a repair attempt (for example, adding extra screws, glue, or other reinforcements) is really worth the effort and how likely it is that more significant damage could occur.
Does anyone have experience with this? From your perspective, is it worth repairing, even when the instability is minimal? What are common causes for this kind of slight wobble in this model? Thanks for your insights!
Hello Mulubu,
I’m familiar with the issue of the Malm nightstand wobbling. Often, the slight wobble is caused by the joints at the screws or dowels loosening over time. Usually, you can easily fix this by tightening the screws again or, if necessary, stabilizing the joints with some wood glue.
If the wobble is minor, it’s usually worth repairing, as this prolongs the furniture’s life and prevents the wobble from getting worse under load. Also, such a repair typically requires little effort and expense.
Tip: Check if the floor where the nightstand is placed is level. Unevenness can make the wobbling worse.
Maybe someone will share more specific repair tips, but I would definitely start by checking the screws first.
Good evening!
Here is a brief guide on how to minimize wobbling:
1. Check the screws: Often, the Phillips screws on the Malm nightstand are not tight enough. Tighten them with a suitable screwdriver, but be careful not to overtighten to avoid damaging the material.
2. Inspect the dowels: Sometimes the wooden dowels are no longer firmly seated in their holes. If they are loose, you can secure them with a bit of wood glue.
3. Use glue for extra stability: Apply wood glue (preferably PVAC glue) carefully to the joints and press the furniture together until the glue dries.
4. Check the floor: As mentioned, make sure the nightstand is standing on a level surface; small felt pads under the feet can work wonders.
Summary: The effort is minimal and the cost low. Personally, I would repair it, as it extends the furniture’s lifespan and quickly stops the wobbling.
If you want to make it even more stable, you can attach small corner braces to the back, but this is usually not necessary.
Kinbu schrieb:
The wobbling is often caused by the joints looseningI can generally agree with that. However, I wonder to what extent a slight play in the connectors of furniture made from particleboard can even be considered “normal” and perhaps part of the allowable construction tolerances.
tolokau schrieb:
secure the joints with wood glueThat might increase stability, but wood glue is not necessarily the best solution for furniture made from this material, as particleboard is often not absorbent enough and the glue hardly penetrates. Additionally, such an intervention is hardly reversible and can cause further problems, for example, if parts need to be replaced later and get damaged.
Therefore, I would advise against “repairing at all costs” if the wobbling is only slight and does not pose a risk to the function. One should carefully consider whether the effort is justified or if a slight preload can simply be tolerated.
What are your thoughts on the advantages and disadvantages of directly reinforcing joints with minimal play?
BAUEVA schrieb:
Wood glue is not necessarily the best solution for furniture made from this materialThanks for the advice, I hadn’t considered that. It also explains why I’ve sometimes read that glue repairs are not recommended for particle board.
tolokau schrieb:
Carefully apply glue to the joints and press the furniture piece togetherBut this seems to be the usual approach, right? I’m wondering if there is a better adhesive or another method specifically suited for IKEA furniture from the Malm series?
The suggestion to attach small corner braces to the back sounds interesting as well. Would that affect the appearance significantly, or is it fairly discreet?
If anyone has tips for a gentle stabilization that is also reversible, I would really appreciate it. My priority is to make the nightstand more stable without damaging its look or material.
PS: Thanks also for the tip about the felt pads. I actually haven’t checked the floor yet.
