ᐅ MALM furniture legs wobble – how can I effectively stabilize them?
Created on: 15 Apr 2016 08:23
Kauus4
I have a problem with the legs of my Malm chest of drawers from IKEA, which start to wobble more and more after some use. The legs themselves are securely screwed in, but I can feel an unpleasant movement that affects the stability. I’m wondering what practical and long-lasting measures can be taken to eliminate or at least significantly reduce this wobbling.
Does anyone have experience stabilizing the MALM wooden legs? What materials or techniques have proven effective? For example, should spacer pieces be used, glued additionally, or is it better to replace the legs entirely? I’m grateful for any tips, especially those suitable for DIY use without expensive special tools or advanced craftsmanship required.
mintra
16 Apr 2016 09:02
To stabilize wobbly furniture legs on Malm dressers, I recommend following a systematic approach:
1. Remove screws and inspect the mounting holes for any tearing or material weakness.
2. If the holes are slightly frayed, gently smooth the wood with fine sandpaper.
3. Fill the holes with suitable wooden dowels and wood glue, then allow them to dry thoroughly (at least 24 hours).
4. Drill new holes with a slightly smaller diameter to ensure a tight fit for the screws.
5. If this is not possible, use screws with washers and, if accessible, lock nuts for added security.
6. For even better durability, threaded inserts can be used, which provide a long-lasting threaded solution. These are specifically available for furniture DIY projects.
Additional reinforcements, such as diagonal braces, are often unnecessary and may be overkill unless the dresser is subjected to extremely high loads. The priority should always be a secure connection of the legs to the main body.
If a glued fix is planned, combinations of wood glue and threadlocker are recommended, although screws will always provide a mechanically stronger connection than glue alone!
By the way: When using wood screws, always choose screws with a larger thread diameter than the original if the threads have become worn out.
BASTIANTI
16 Apr 2016 10:27
lechen schrieb:
Simply insert a wooden toothpick or a small wooden strip into the hole, add some wood glue, then screw in the screw.
Great tip! I did the same, and it works perfectly 🙂
Here’s an additional trick from me: If the legs move slightly due to firm contact with the floor, placing a small rubber or felt pad under each leg can work wonders. It provides extra stability and protects the floor.
Kauus4 schrieb:
Is there a way to reinforce the thread itself without completely taking the furniture apart?
Sure, if you can access it, you can tighten the threaded hole using small wooden dowels and wood glue, without major disassembly. Just be patient while it dries! 🙂
deoke
16 Apr 2016 12:59
Kauus4 schrieb:
What do you think about the idea of adding some kind of diagonal bracing under the dresser to stabilize wobbly legs?
The idea can generally make sense if the piece of furniture is subjected to significant leverage forces, for example from heavy loading or if it stands on uneven floors. However, this often conflicts with the clean design of a MALM unit.
If you want to stabilize the legs, it is better to first address the main causes of wobbling:
- Tightening screws using threadlocker
- Repairing worn threaded holes with wooden dowels or threaded inserts
- Checking the contact points of the legs for proper fit
Diagonal bracing can help reduce minor vibrations as a secondary measure, but in your case it might not be necessary if you optimize the fastenings.
One more question: Is the dresser standing on carpet or a hard floor? On carpet, furniture tends to wobble less, while on hard floors it may behave differently.
