ᐅ Malm dresser squeaks when opened – what should be considered?
Created on: 15 Feb 2024 09:23
klafar
I have noticed that the drawers of my IKEA Malm dresser are increasingly squeaking when opened. The noise seems to come from the drawer slides. I assume that the material is rubbing in some areas or that the guides need slight adjustment.
I am interested in knowing what to consider specifically when maintaining or repairing a Malm dresser to fix the squeaking without affecting its function.
Are there any special care instructions, suitable lubricants that can be used, or perhaps known weak points of this dresser that I should be aware of?
I appreciate any tips related to technical details and safe handling!
SUBEN60
15 Feb 2024 13:14
The question of warranty is important.
IKEA provides a limited warranty, which typically does not cover damage caused by improper care or misuse.
Therefore, I recommend using only care products that are specifically designed for furniture, such as silicone or Teflon sprays, as mentioned earlier.
WD-40 is primarily a cleaner and rust remover, not a long-term lubricant – and its oily residue can attract dust, which may increase wear on furniture.
In short, a pure Teflon spray is indeed better suited than WD-40 for a Malm dresser.
anken
15 Feb 2024 14:51
Additionally, I would like to point out the importance of regular maintenance.
Sliding rails should be checked and cleaned every few months, especially in dusty environments.
Equally important: avoid assembling the entire unit with dirty parts, as this increases wear and squeaking.
If the drawer sticks despite lubrication, check the alignment of the chest of drawers. Minor warping due to moisture or an uneven floor may be the cause.
MOMIRA
16 Feb 2024 08:03
I had a similar issue with my Malm.
The squeaking was caused by a missing spring in the sliding rail.
I got a replacement part, installed it, and the noise stopped.
Maybe check the mechanical condition of the guide rail.
RENMA
16 Feb 2024 09:12
klafar schrieb:
Would pure Teflon spray instead of WD-40 be the safer choice?
Yes, that is the knowledgeable answer.
It is also important to apply the spray very sparingly to avoid transferring lubricant residues unnecessarily onto the dresser sides and the floor.
When disassembling, it is best to carefully document all parts to ensure smooth reassembly.
U
usJamie
16 Feb 2024 10:47
Just a quick note:
Do not use Vaseline or grease-based lubricants.
They attract dust and leave residues.
Silicone or Teflon spray is best, and after lubrication, open and close the drawer a few times to distribute the lubricant.
