I have a Malm dresser from IKEA that is unfortunately quite dirty. The main issue is stains and slight discoloration on the surface, probably caused by everyday marks like drink spills or dust that have settled over time.
I’m particularly interested in how to clean the dresser properly and gently, without damaging the surface or affecting the finish. Which cleaning products are suitable, and which should I definitely avoid?
Also, it would be helpful if someone could provide a step-by-step guide on the best way to clean this specific dresser and its material.
Thanks in advance for your tips and experiences!
Hello ole42,
To properly clean the Malm dresser, I recommend the following steps:
1. Remove loose dust first using a dust cloth or microfiber cloth.
2. Prepare a solution of lukewarm water and a few drops of mild dish soap for stains.
3. Apply the solution with a soft sponge or cloth, always wiping in the direction of the wood grain.
4. If stains are very stubborn, you can use a very diluted vinegar solution, but test carefully as it may damage the finish.
5. After cleaning, wipe again with a clean, damp cloth and then dry immediately.
Common mistake: Never use too much water, as absorbed moisture can cause the dresser to swell. Harsh cleaners or abrasive agents should also be avoided.
I hope this helps you.
gojan7 schrieb:
Do not use harsh cleaning agents, as they can damage the surface.That is generally true, but I would argue that some people simply don’t want to follow the usual cleaning recommendations and still opt for stronger products because they act faster.
My theory: these “gentle methods” often don’t actually clean thoroughly but just cover up the dirt. And who wants to scrub forever? Stronger cleaners are quicker and more effective.
Of course, you have to be careful, but a balanced approach is important here. There are definitely gentle specialty cleaners that do more than just water and dish soap.
At the same time, it’s also a matter of weighing the benefits against some degree of surface wear.
NOAHSAU schrieb:
There are indeed gentle specialized cleaners that are more effective than just water and dish soap.That’s a valid point. However, this approach assumes you already know which cleaners are compatible with the paint finish. Reliable information from Ikea is often lacking, which can potentially be risky.
I would initially recommend using mild agents and then carefully weighing the risks of using stronger chemicals. Additionally, I find LOGEMIN’s warning about the dangers of moisture crucial. An incorrectly dosed cleaner or too much water can cause more damage than light dirt.
