ᐅ Malm drawers open on their own – how can I prevent this?
Created on: 15 Jun 2024 08:37
PAJUNU
PAJUNU
15 Jun 2024 08:37
I have a problem with my IKEA Malm dressers: the drawers open by themselves without me pulling on them. This especially happens when the furniture is moved slightly (e.g., during cleaning) or if the floor is not completely level. I suspect that the design of the drawer slides or the drawer mechanism causes them to slide forward easily.
My question is: How can I prevent the Malm drawers from opening on their own? Are there any structural modifications, simple tricks, or accessories that could help? I would prefer a solution that doesn’t require much effort or major adjustments.
Important to know: The drawers are often not fully loaded, but not empty either. My main concern is that they stay securely closed, especially when other people enter the room or if they are bumped lightly.
I look forward to your tips or experiences, thank you!
RENMA
15 Jun 2024 09:13
Regarding the issue with Malm drawers that open by themselves: this is often due to the absence of a self-locking mechanism on the slides of this model. A few suggestions I can recommend:
1. Anti-slip pads or thin felt strips applied inside the drawer or on the slides can increase friction, preventing the drawer from sliding out too easily.
2. Installing small magnets on the front of the drawer and the cabinet frame can help keep them closed.
3. Alternatively, small mechanical safety catches—usually designed for kitchen cabinets—can be fitted to prevent the drawer from swinging open on its own.
4. Also, check whether the chest of drawers is level, as any tilt can make unintended opening easier due to the effect of gravity.
These solutions typically can be implemented without major modifications and are usually the most effective.
Palenar
15 Jun 2024 11:47
RENMA schrieb:
This is indeed often due to the absence of a self-locking mechanism in the slides of this model.
Exactly, it’s worth understanding the problem in detail here: The drawer slides used in Malm furniture are usually either roller or ball-bearing types that often lack a locking feature in the closed position. This means that as soon as no force is applied against the opening direction, the drawer may open slightly due to its own weight or incline.
What can be done technically:
- First, check if the dresser is level, for example with a spirit level. A slight tilt toward the room can encourage unwanted opening.
- Then, you can install a small mechanical catch or drawer lock. These are available online or at hardware stores and work similarly to a latch that holds the drawer in place.
- For DIY enthusiasts: Adding a small spring or an extra angled clamp on the side of the slide increases friction and helps keep the drawers in position.
- Magnetic catches are also recommended but need to be positioned precisely; otherwise, they may rub or provide insufficient holding force.
I’d like to know whether this problem occurs with only a few or all drawers, and if you have already tried any modifications yourself. Because depending on material and weight differences, the optimal solution can vary.
If you’re interested, I can also send you a short guide on installing a mechanical lock that I have used on similar models.
Franck
15 Jun 2024 12:21
Stick anti-slip pads onto the running rails. Check the floor and align the dresser. Install magnetic catches, if necessary. That should be enough.
TEOZAR
16 Jun 2024 07:59
PAJUNU schrieb:
How can I prevent the Malm drawers from opening by themselves?
This is a common issue with IKEA Malm dressers. My recommendation is a combination of several measures:
1. Make sure the surface the dresser stands on is perfectly level – this has a significant impact on how the drawers behave. You can try placing small shims under the feet if needed.
2. Use magnetic catches or drawer locks, which are even available as accessories specifically for IKEA furniture. These are easy to install and make a big difference.
3. If you’re handy, you can mount small brackets or clips on the drawer slides to increase friction.
4. Load the drawers slightly differently so the weight is more evenly distributed, reducing the chance of drawers opening due to gravity.
RENMA schrieb:
Non-slip pads or thin felt strips… increase resistance
– I can confirm this; I now use both combined, and the drawers stay reliably closed.
If you need more details, I’m happy to help!
