ᐅ Malm drawers often come off their tracks – are there replacement safety catches available?
Created on: 24 Nov 2018 13:02
Tabuku
Tabuku
24 Nov 2018 13:02
Hello everyone, I have a specific problem with my Ikea Malm bed. The drawers under the bed often fall out unexpectedly, even though I don’t pull them all the way out. It seems to me that the locking mechanism or the catches that hold the drawers on the runners are not very reliable. My question is: Are there replacement catches or special retrofit mechanisms available for the Malm drawers to prevent them from falling out like this? I have already searched through various forums but haven’t found a clear solution yet. I’m mainly interested in practical advice or official replacement parts. Thank you in advance!
Z
zartra
24 Nov 2018 13:47
Hello, most Malm drawers have plastic locks on the side that can break easily. Ikea sells replacement parts, so you can check the service section or ask directly in a furniture store. Sometimes a small wooden shim can also help secure it.
Timurki8
24 Nov 2018 14:15
Oh dear, I’m familiar with the problem of drawers falling out! 🙂 The best solution I’ve found is actually to get the original Ikea safety catches and also use small metal fittings to keep the drawer securely “captured” so it doesn’t unexpectedly fall out. You don’t want to have to start a rescue operation every time you just want to pull something out quickly :-)
CORYGAU
25 Nov 2018 09:12
zartra schrieb:
Ikea sells replacement parts, just check the service section
That would be the official route, but it is important to critically consider whether these replacement parts actually provide a long-term solution or just a temporary fix. The plastic guides tend to wear out, which generally suggests a design flaw or insufficient material choice.
Are there any reports on whether aftermarket metal fuses offer better durability? Or does anyone know of alternative designs for retrofitting that would mechanically prevent failure altogether? I think this discussion is important since mass-produced furniture often fails due to such details.
elgla
25 Nov 2018 11:30
I can easily understand how annoying it is when drawers come out every time you move them. Once, a drawer fell on my toes while I was cleaning – not funny!
Timurki8 schrieb:
adding small metal fittings
That sounds like a practical solution that could also ease my concerns about stability.
Does anyone have specific recommendations on which metal fittings or locking mechanisms work best? I want to avoid making too many changes to the furniture, as it should keep its original appearance.
Pome60
26 Nov 2018 08:47
Hey everyone, I find this topic really interesting! 😀
I had the same problem with my Malm drawers and actually found a very simple and inexpensive solution!
I attached small rubber bumpers to the inside parts of the drawer slide assemblies. This slows down the movement a bit and prevents the drawer from getting stuck or falling out. It’s easy to do, doesn’t require any replacement parts, and works great!
Give it a try – it’s really clever and saves you from having to buy expensive spare parts. Now everything fits tight and secure again 😄!!
