I installed the drawers on my Ikea Malm bed to create more storage space underneath. Unfortunately, the drawers are very stiff and require quite a bit of force to pull out and push in, which is quite frustrating. It’s especially noticeable that not all the drawers behave the same; some are much harder to move than others.
I have already checked if the rails are properly aligned and if there are no obvious blockages or deformations. They also seem to be clean, as far as I can tell. The furniture store or the manual only offer general advice, it seems.
Does anyone here have experience with Malm drawers and can explain what might be causing this? Are there any special tips for installation or readjustment that I should know about?
I would really appreciate detailed tips or suggestions, and I’m also open to alternative solutions or tools you might recommend. Thanks in advance!
Thank you for the many responses!
Today, I will remove the drawers and take a closer look at the runners.
Regarding alignment: The screws seem tight, but I wonder if they can simply be loosened to adjust, or would that risk causing more damage?
Additionally, I’m puzzled that some drawers slide much more smoothly than others, even though they are supposedly identical. I will reduce the load on the drawers during the next inspection, as suggested.
One question remains: Is it advisable to completely remove the runners and reinstall them to achieve better adjustment? Or are they designed in a way that only minimal screw adjustments should be made?
I would appreciate your assessment.
Johnathon27 Jan 2017 13:08LEVI2 schrieb:
Is it recommended to completely remove and reinstall the slides to achieve better alignment?Normally, the slides are designed so that you can fully remove and reposition them if you are not satisfied with the alignment. It’s important to keep track of the screws when removing them and carefully note the exact position of each slide to ensure the drawers run correctly afterward.
If some drawers slide more easily than others, this can often be due to differences in installation tolerances or material variations (in the wood or the rollers).
Be careful not to overtighten the screws. Sometimes the rails can warp slightly, which can significantly affect the drawer movement.
If you feel confident, try removing the slides completely and realign all the rails—ideally using a spirit level or angle gauge.
One more tip: before tightening the screws, you can test the drawer movement by placing a felt pad or thin tape underneath to see how it changes.
Feel free to share how it goes once you have the slides removed!
Hello LEVI2,
I know how frustrating these things can be – when a drawer sticks, it really adds stress to everyday life. I think it’s great that you’re thinking it through so carefully and approaching it systematically.
Sometimes you only realize how much energy small daily obstacles cost until you actually fix them. Maybe you could develop a little routine to lightly maintain the drawers every few weeks?
If you’re unsure about unscrewing parts, take some photos beforehand or mark the position with a pencil – that way you can readjust more easily without worrying about making big mistakes.
If you ever feel your motivation slipping, here’s a little push: you’re doing well, and the problem is definitely solvable! 🙂
Reminder:
I think this step makes sense, but one should also consider the possibility that the construction itself is limited by the choice of materials.
A completely free movement is unlikely to be achieved at this price/performance ratio.
It is important to set a realistic goal and then check whether the result is still satisfactory.
Johnathon schrieb:
If you dare, completely remove the guides once and realign all the rails from scratch
LEVI2 schrieb:
Would appreciate an assessmentYes, it is quite common and recommended to completely disassemble the drawer slides and then realign them. Provided you have some patience and the right tools.
Important points:
- Use a good tape measure or ruler
- Work with a spirit level
- Loosen the screws one by one, realign, then tighten
This way, you can gradually find the optimal position until the drawers run smoothly.
If you only adjust a few screws without loosening the rails, you can make minor corrections, but a full realignment is usually more effective.
Good luck!
