ᐅ Malm drawer handles often break – how can I improve their durability?
Created on: 19 Apr 2023 10:23
Par-te1
Par-te1
19 Apr 2023 10:23
Hello everyone, I have a major problem with the drawer handles on my IKEA Malm dressers. They have been damaged multiple times or even broken off completely, although I use them carefully. I suspect that the attachment method or the material is not ideal, especially with frequent use of the drawers. Has anyone experienced something similar and maybe has tips on how to improve the durability of the Malm drawer handles? Are there alternative fastening methods, reinforcements, or replacement parts that are more sturdy? I look forward to your suggestions!
Ankeli
19 Apr 2023 10:55
It is best to tighten the screws and, if possible, use longer ones. You can also use small washers to ensure the handle fits more securely.
gregto
19 Apr 2023 11:17
Hello Par-te1, I’m familiar with the issue regarding the Malm drawer handles. These handles are made from relatively thin plastic, and the fastening with single screws into the drawer fronts is not very durable.
One option is to replace the screws with higher-quality metal ones of a larger diameter – this provides better grip. Additionally, applying some wood glue or epoxy resin into the screw hole can help stabilize the material if the hole has already become worn out.
If you have some DIY skills, it also helps to reinforce the handle holes from the inside with a small wooden patch or even a thin metal plate. This way, the pulling force is distributed more evenly and the handles are less likely to break.
Alternatively, many users choose different handles to replace the originals, as those often have sturdier mounting points.
I hope these suggestions help you!
Par-te1
19 Apr 2023 11:42
gregto schrieb:
One option is to replace the screws with higher-quality metal alternatives of a larger diameter
That sounds reasonable – so far, I have mostly used the original screws because I thought they were the exact fit.
Is there a recommendation for a particular screw size or type (e.g., pan head, Torx) that has proven to be especially reliable?
Ankeli schrieb:
use small washers to help the handle fit better
I can definitely see that, to help distribute the pressure on the surface. Thanks in advance for the quick tips!
V
vinpau
19 Apr 2023 12:05
Great topic! I also had trouble with the handles – it’s so frustrating when they keep breaking! 🙂
I simply got different handles from Amazon that fit Malm perfectly, but they are made of metal with reinforced screws. Since then, no more problems!
It’s amazing how much of a difference that makes. A simple screw issue shouldn’t be underestimated – give it a try, it’s really satisfying when everything holds again! 🙂
anken
20 Apr 2023 09:13
Hello everyone, I would like to add that the material of the drawer front on Malm is relatively thin. Therefore, point loads from the screws can quickly become an issue.
A targeted reinforcement would be to attach a strip with a larger contact surface on the back of the front panel when removing it. This helps distribute the pulling force more evenly, preventing the screws from loosening too quickly.
Alternatively, the handles can also be fixed using construction adhesive in combination with screws, which increases stability. This method is a bit more labor-intensive but effective in the long run.
