ᐅ Malm drawer handles keep breaking off – how can I attach them more securely?
Created on: 25 Feb 2022 08:37
Ixgigo
Ixgigo
25 Feb 2022 08:37
I have been experiencing an issue for some time where the drawer handles on my Malm dressers keep breaking. The handles are made of plastic and are attached to the drawer fronts with two screws. Despite careful use, they seem quite fragile and often break at the attachment points or sometimes even in the handle itself.
I suspect the material isn’t very durable, but I also want to make sure the mounting itself is really secure. Has anyone had experience with Malm drawer handles and can offer advice on how to better fix the handles so they don’t break so easily?
I’m also open to suggestions for alternative mounting methods, such as using different screws, reinforcements inside the drawer, or even replacing them with other types of handles that hold up better.
Thanks in advance!
Espen
25 Feb 2022 09:12
I recommend not overtightening the screws and using washers. This helps distribute the force more evenly and prevents the plastic material from tearing as quickly.
draleo
25 Feb 2022 14:01
To improve the fastening of Malm drawer handles, it is important to first choose the appropriate screw length and thickness—thick enough to prevent material breakage, but not too long to avoid a loose fit.
Additionally, I recommend reinforcing the attachment points inside the drawer front with small metal or wooden washers. This increases the bearing surface and better distributes the tensile forces, which often results in longer durability, especially for plastic handles.
Alternatively, small metal threaded inserts can be installed into the wood of the drawer front. These provide a significantly more stable hold for the screws compared to screwing directly into wood or chipboard.
Avoid overtightening the screws as well as sudden loads or impacts when using the handles. The material quality of Malm handles is not particularly robust, so mechanical reinforcement is advisable.
PLOMA
26 Feb 2022 10:43
Hello Ixgigo,
Regarding the issue of Malm drawer handles frequently breaking, several factors play a role together:
1. Material and shape of the handles: The Malm handles are made of ABS plastic, which is lightweight and affordable but not optimized for high stress during sudden use. The narrow connecting points are particularly prone to breaking.
2. Attachment method: The two screws that connect the handles to the drawer front usually go directly into the MDF or particleboard material. Since these engineered wood products often have less grip strength near the veneered surface, material fatigue occurs quickly here.
3. Type and length of screws: Often self-tapping screws are used, which make assembly easier but are less stable over time compared to wood screws with proper threads. Also, the screws should not be too short in order to grip well, but not too long to avoid damaging the inside of the drawer.
Based on these points, I would recommend the following steps:
- Remove the original screws and replace them with high-quality wood screws with good threading, preferably with a flat head that rests on washers.
- Use washers made of metal or hard plastic under the screw heads to better distribute pressure and prevent the handle material from breaking.
- For the attachment points, I recommend mounting small flat wooden blocks or dowel discs inside the drawer front behind the screw holes. These hold the screws better and prevent the particleboard from breaking out.
- If you have access to threaded inserts for wood, these can be installed to improve screw hold. Metal threaded inserts provide long-lasting stability even with frequent pulling on the handles.
- Finally, make sure to tighten the screws with a torque wrench or by hand without overtightening. Over-tightening puts additional stress on the plastic material.
An alternative would be to replace the handles with metal furniture knobs, which have a more robust construction and are usually attached with a single screw. However, these will look different.
How exactly are your handles currently attached? Are the screws going directly into the drawer front, or is there an additional strip or facing? Have you already subjected the handles to higher stress or sudden pulling? This would help with the analysis.
