ᐅ Malm bedside table joints are widening – how can I fix this?
Created on: 23 Jun 2020 08:37
luflo
luflo
23 Jun 2020 08:37
Some time ago, I bought a Malm nightstand from Ikea, and I have now noticed that the gaps between the individual wooden parts have become noticeably larger over time. The joints look as if the wood or connections have loosened or shifted a bit – I suspect this is due to humidity or temperature changes.
My question is: What is the best way to repair these gaps so that they close flush and cleanly again? Are there specific materials, such as wood glue, filler, or sealants, that are especially suitable for this? Should I perhaps tighten all the screws again or even take the parts apart?
Of course, I want to avoid damaging the piece of furniture or worsening its appearance. Does anyone have experience with Malm furniture or similar issues and can offer advice on how to properly repair such gaps?
Thanks in advance for any help!
Dirkmin
23 Jun 2020 09:16
regarding the gaps in your Malm nightstand: such gaps can expand or come loose in particleboard furniture when humidity levels fluctuate. This is typical behavior for engineered wood products, especially if they are not properly sealed.
I recommend the following steps:
1. Check and, if necessary, tighten the screws – sometimes the connections simply become loose due to mechanical reasons.
2. Clean the gaps before treating them.
3. Use a special MDF wood filler or a color-matched filler that can be easily sanded to fill the gaps.
4. After filling, lightly sand the surface and treat it with a suitable paint or a thin clear varnish to protect the gap from moisture.
Disassembling the furniture parts is only necessary if screws are pulled out or the structure is unstable.
Do not use general-purpose filler or acrylic, as these tend to crack quickly when there is movement.
pinpa
23 Jun 2020 09:45
Dirkmin schrieb:
Disassembling the furniture parts is only necessary if screws have been ripped out or the structure is unstable.
That sums it up well – sometimes the wood just needs a bit more care. I carefully applied wood glue into the joints of my Malm dresser and then clamped it with a few clamps until it dried. I scraped off the excess glue in between and later sanded it lightly; it looked really good 🙂
Oh, and very important: only tighten the clamps lightly, otherwise the wood will be compressed too much and end up worse than before ;-)
bijo54
23 Jun 2020 10:03
Tighten the screws, fill the joints with wood filler, then sand and paint. Done.
rickey
23 Jun 2020 10:38
luflo schrieb:
The joints look like the wood or connections have loosened or shifted a bit – I suspect this happened due to moisture or temperature changes.
I’m very familiar with this – it’s frustrating when you like a piece of furniture and it slowly starts to come apart. Fortunately, it’s usually repairable.
I would first check the cause: Is the bedside table perhaps placed too close to a humid area (for example, near plants or an open window)? Because if the cause isn’t addressed, sealing the joints will only provide a temporary fix.
Maybe you can roughen the joints slightly with fine sandpaper and then fill them with wood glue mixed with some wood dust from sanding. This way, you create a color-matched filler that bonds well.
Good luck, and let us know how it goes!
LANICOLE
24 Jun 2020 07:22
Hello luflo and everyone with a similar issue,
I would like to add a brief step-by-step guide on how to properly repair joints on a Malm bedside table:
1. Preparation: Thoroughly clean the joints using a brush or compressed air to remove any dust or dirt residues.
2. Screw check: Carefully tighten all screws. If they are loose, the joints can widen.
3. Filling the joints: Mix wood glue with fine sanding dust (from similar wood) until you get a moldable paste.
4. Apply the paste into the joint with a small spatula or knife, pressing it in well.
5. Remove any excess material immediately.
6. After drying, sand the surface smooth with fine sandpaper (grit 220).
7. Sealing: For the final treatment, use a suitable varnish or furniture polish.
Common mistakes are filling the joints only superficially or not checking the screws before applying the filler. Both lead to problems reoccurring quickly.
Good luck with your repair!
