ᐅ Malm bed squeaks despite new screws – what could be the cause?
Created on: 11 Apr 2024 18:34
LueldoHello everyone, I recently bought an Ikea Malm bed and found that it still squeaks whenever I move, even after replacing all the screws. I tightened the screws firmly, checked them multiple times, and also tried some assembly spray, but the noise remains. The squeaking occurs despite the connection screws being new and intact.
My question is: What could cause squeaking in a relatively new Malm bed even with new screws? Could it be due to the construction, wood quality, or perhaps the included connector fittings? Are there any known weak points that might need additional attention? I would appreciate any tips and experiences on how to make the bed permanently solid and noise-free.
Lueldo schrieb:
Still squeaks after replacing all screws as soon as I move.The squeaking despite new screws is often not caused by the screws themselves, but by the connection between the wood surfaces. For models like the Malm, the construction can be so tight that small movements cause friction.
A systematic approach is advisable here:
1. Check screws for correct seating (not just tight but also flush with the surface).
2. Inspect wood joints: Are they clean, with no damaged wood fibers?
3. Fill gaps with wood glue (especially at dowel joints).
4. Check all moving parts such as slat supports and, if necessary, dampen them with felt pads or thin rubber strips.
It often helps to treat the contact points involved with a dry lubricant like wax or fine Teflon spray. WD-40 can stop squeaks temporarily but is more of a short-term fix and may damage the wood.
Usually, this allows for a lasting reduction of noise.
Lueldo schrieb:
Could it be due to the construction, wood quality, or perhaps the included connector fittings?Basically, besides the screws and the wood, you should also check the connecting elements like cam locks and metal brackets. With Ikea beds, these are often responsible for noises when they loosen slightly or when the contact with the wood causes friction through micro-movements.
A few tips:
- Check if all cam locks are properly turned and fully seated.
- Retighten connected screws after one night, as the wood may settle slightly due to moisture.
- Lubricate metal parts sparingly using dry methods like graphite powder, which protects and lubricates without leaving stains.
Regular inspection is very important because wood swelling caused by humidity can lead to changes that increase squeaking noises. In the Malm series, the central support panel is also often a weak point—this can cause slight twisting in the bed frame.
Hey, I know the problem with squeaky Malm beds all too well! 🙂
What worked really well for me was sticking thin felt pads under all the points where wood meets wood. This reduces friction and really eliminates the annoying squeaking completely.
Before, I also tried tightening the screws multiple times, but that only helped temporarily. The wood probably shifted slightly, so the noise stayed.
A small tip: Don’t tighten the screws too much, because that compresses the wood and can cause cracks or stresses that lead to squeaking again. It’s okay if the bed is a little bit wobbly, but there shouldn’t be any play. I was really surprised how such a simple trick could help!
So, just try putting a strip of felt on the critical spots – and if someone tries it, feel free to share whether it worked!
noge58 schrieb:
Glue thin felt pads under all contact points where wood meets wood! This reduces friction and completely eliminates the annoying squeaking.This is a very practical solution that I can also recommend. Additionally, it is worth noting that the slatted frame holder itself or the support points of the slats often cause noises.
If the screws and connections have been checked and tightened, please also consider the following points:
- Check that the slats rest firmly and evenly without any play.
- Possibly install small rubber strips or felt pads between the slats and the frame.
- The central support board, which is standardly hooked in on Malm beds, can vibrate slightly; fixing it with wood glue or additional clips helps here.
Replacing the entire set of screws rarely resolves the squeaking on its own. Usually, it is the combination of various small micro-movements that add up.
