ᐅ Malm bed squeaks at the side panels – how can I fix it?
Created on: 23 Mar 2024 08:37
ladufe
ladufe
23 Mar 2024 08:37
I have a Malm bed from Ikea, and I’ve noticed that the side panels have started to squeak slightly when lying down or moving in the bed. The creaking usually comes from the areas where the side panels connect to the headboard and footboard. It’s not excessively loud, but over time it becomes quite annoying.
I suspect that some moving parts are not properly secured, or that the wood and screws are rubbing against each other in some way. I have already tried tightening the screws, but the problem persists.
Has anyone experienced similar squeaking noises with Ikea beds, especially with the side panels of the Malm? What repair steps might be effective here? Should I use cloth or felt tape, or are there better methods to permanently fix the squeaking?
Thanks in advance for your advice!
Jeanbar
23 Mar 2024 09:12
Hello ladufe,
First of all, your idea to tighten the screws is definitely on the right track. Squeaking in beds often occurs due to slight movements between the wood and the fasteners.
I recommend the following steps:
1. Check the screws and wooden dowels: Sometimes the dowels are loose, which can cause misalignment and friction—meaning wood movement.
2. Attach felt or foam pads at the contact points: These prevent two wooden surfaces from rubbing directly against each other, which is usually the cause of the creaking.
3. Tighten all screws with an appropriate screwdriver, but not too tight to avoid damaging the wood.
4. Check if the hinges or connecting parts (if installed) can be lubricated. Sometimes a drop of a suitable lubricant like silicone spray helps (avoid WD-40, as it can damage the wood).
If you like, you can carefully disassemble the bed, lightly treat the contact surfaces with wax (e.g., beeswax or furniture wax), and then reassemble everything.
These are proven mechanical solutions that require little effort. If this doesn’t help, feel free to reach out again!
Filippo
23 Mar 2024 10:46
Hello ladufe,
In addition to Jeanbar’s advice, I would like to recommend a more detailed approach, as Ikea Malm beds specifically use metal fittings to connect the side panels, which can sometimes vibrate even when screws are tightly fastened.
The following procedure might help:
1. Completely loosen the screws and remove the side panel.
2. Check the screw holes for fraying or larger indentations – these can prevent the screws from holding securely and allow movement under load.
3. If necessary, you can carefully glue wooden dowels with wood glue and reinsert them to improve the stability of the screw anchoring. Note: This will make the fixing more stable in the long term!
4. Reattach the side panel with dried glue and gradually tighten all screws evenly so that the tension is distributed.
5. To calm the contact surfaces between the side panel and headboard/footboard, Ikea often uses metal brackets, which can have slight play. I have had good results treating these areas thinly with furniture wax or paraffin oil.
6. Also, a very thin strip of fine felt tape along the joint can help dampen noises – but it is important that no screw becomes loose as a result.
I have one more question: Does the bed squeak more often in dry air or with temperature fluctuations? Wood expands and contracts and can react differently to tension, which can worsen the problem.
If you notice this, using a humidifier in the bedroom might help reduce the wood movement somewhat.
I hope these tips are helpful to you!
andre3
23 Mar 2024 11:08
That is a good idea. Additionally, I would like to point out that in such constructions, the problem can also be due to wear of the connecting elements. Metal fasteners in flat-pack furniture are often made from thin steel sheets. If the holes in the wood become enlarged over time or if the screws loosen slightly, play occurs, which can cause creaking under changing loads.
A durable solution is often to replace the screws with higher-quality ones that have a slightly larger diameter (but only minimally larger to avoid damaging the wood), or to insert small felt washers/spacers that act as buffers.
Spraying the metal connections with a dry lubricant (e.g., graphite powder) can also help without affecting the wood, which can be risky with oils or greases.
A controlled, step-by-step approach with attention to previously mentioned wood protection measures is recommended to accurately identify the cause.
bauku
24 Mar 2024 07:51
Hello ladufe and everyone else!
It’s great to see you tackling such a seemingly small but annoying problem in such detail! :-)
I had exactly the same issue with my Malm bed; the squeaking from the side panels was really irritating, especially when guests were over 🙂
What worked really well for me:
1. Take the bed apart (which is actually quite easy with Malm!)
2. Apply something normally used for furniture upholstery at all contact points and joints (felt pads, which are very thin and smooth)
3. Before reassembling everything: don’t tighten the screws all the way at once, but gradually, so the wood and metal parts fit together snugly
4. Once more, go over all screws again, in case anything loosened during the initial assembly
I’d also like to mention that sometimes the slatted base support can squeak too. If you have rubber or plastic caps there, they can be the culprit as well.
And the best part: after doing this, the squeaking was completely gone! I’m sure it will work for you too :-)
dijan
24 Mar 2024 12:25
bauku schrieb:
I wanted to add the tip that sometimes the slatted bed base support can also squeak
That’s true! Sometimes the squeaking is the sneaky culprit – the subtle rubber or plastic contacts can really misbehave due to pressure and friction 😉
A little trick of mine is to lightly treat the contact surfaces with a wax or candle strip before assembling – this reduces friction.
And another thing: if you have vinyl or hard plastic sheets as a base, they should always be clean and dry, otherwise they tend to amplify the noise.
Otherwise, I agree with the previous comments: tightening screws, felt pads, and the like are the best friends for these kinds of bed problems!
