ᐅ MALM Bed Squeaks After Climate Changes – What Can I Do?
Created on: 14 Nov 2021 08:23
sarson
I have recently started experiencing a problem with my Malm bed from IKEA. Over the past few weeks, especially since the significant changes in temperature and humidity due to autumn, the bed has begun to squeak intermittently when lying on it. It’s not constant but occurs whenever I move or slightly change the load. I suspect that the “climate change” in the room plays a role here – that is, the drying out of the wood or shrinking and swelling caused by fluctuations in moisture.
Has anyone had similar experiences or any tips on how to eliminate or at least reduce the squeaking? I have already tried tightening all the screws, but without success.
Looking forward to your advice!
pilous
14 Nov 2021 12:51
sarson schrieb:
Beeswax sounds good, but where can you get it cheaply and in a convenient form?
Is there already any insight on whether the squeaking is actually caused solely by the wood? Sometimes people overlook that the slatted frame, screw quality, or type of joint can also contribute to the problem.
In addition, I think it's sensible to first quickly check whether the screws might already be slightly stripped, which reduces their holding strength, before trying traditional home remedies. Otherwise, tightening them further could actually make the problem worse.
Beeswax is usually available inexpensively at craft stores or online, but I would recommend a systematic check first.
sarson
14 Nov 2021 13:15
pilous schrieb:
I would also prefer a systematic check.
Of course, I’m doing that. I have already retightened the screws, but I haven’t yet systematically checked every connection point in the frame.
The issue of overtightening is a good point. Should I replace the screws then, or is there a way to fill the hole in the wood?
The slatted frame is mounted quite solidly, so I don’t initially assume it’s the direct cause.
nojaus
14 Nov 2021 14:06
Hi sarson,
I understand how annoying a squeaky bed can be at night. What helped me was adding felt or foam strips at the contact points between the wooden parts. This noticeably reduces the friction and can especially help with swelling caused by moisture.
If you feel unsure about disassembling it, start with the visible areas and try to secure as much as possible without taking everything apart right away.
Fingers crossed you manage to fix it quickly!
boelnu
14 Nov 2021 15:27
GUMARTINA schrieb:
Try... lubricating with wax or silicone spray
I would generally advise against silicone spray, especially on wood. It can damage the surface or leave oily residues that are slow to dry. I have had very good results with furniture wax or solid paraffin from candles – these penetrate the wood well without causing any harm.
Also, if the screws are really tight, the issue often comes from small movements in the wood joints caused by changes in humidity and temperature. The only solution is regular retightening and, of course, lubrication.
Good luck!
rebufar
15 Nov 2021 08:14
A slightly different perspective:
Squeaking is almost a sign that the wood-based material is alive. Maybe we should simply accept that natural materials react to temperature changes. Of course, you can keep tightening screws, lubricating, or padding – but over time, it won’t completely go away.
Why not try to be a bit more relaxed about bed noises? As long as there’s no stability issue, it’s a natural part of the furniture. ;-)
sarson
15 Nov 2021 09:52
I can relate to that, but at night it can get loud enough to really be disturbing. It’s not a major issue, but since I like to sleep peacefully, I want to reduce the noise as much as possible.
I’m going to systematically check all the screws and get some beeswax. Thanks to everyone for the tips so far!
If anyone has advice on the best way to apply beeswax to wooden joints, please share.
