ᐅ Making Ikea Metod drawers quieter and closing more smoothly
Created on: 12 Nov 2022 09:37
Matsli
Matsli
12 Nov 2022 09:37
I recently installed a kitchen with Ikea Metod drawers and noticed that the drawers sometimes close somewhat loudly and jerkily. I am looking for effective ways to make the drawers quieter and to achieve a smoother closing overall.
I understand that Ikea already uses soft-close drawer slides with Metod, but apparently, this is not always sufficient, especially when the drawers are fully loaded or if something is slightly misaligned.
Does anyone have practical experience or tips on measures to reduce noise and improve the closing function? I am particularly interested in:
- Adjustment options on the slides
- Alternative damping components or small modifications
- Maintenance or lubrication of the guide rails
Thanks in advance for your suggestions!
bapar
12 Nov 2022 14:03
Hello Matsli,
Your question is very specific, and the topic is definitely relevant because Metod drawers are solid, but they don’t always close perfectly smoothly in every situation.
First, it is important to ensure that the drawers are properly aligned. A slightly misaligned drawer slide can cause unwanted rattling and jerky closing. You should use a screwdriver to check if the drawer slide is parallel to the side walls and that the drawer is not skewed.
Regarding damping, there are two levels:
- The integrated damping in the Metod slides is usually located at the rear of the extension. Some models have a small rubber buffer damper that can wear out over time.
- There are retrofit dampers, so-called soft-close adapters, which you can install to slow down the closing action further if the original damping is not sufficient.
For maintenance, I recommend using a dry lubricant (e.g., PTFE spray) on the metal slides — but not oil, as it attracts dust and can make the slide sticky in the worst case.
Feel free to ask more specifically about your drawer type or share pictures of the drawer setup for more targeted advice.
In summary:
- Carefully align the drawers
- Check the original damping and retrofit if necessary
- Treat the slides with a PTFE dry lubricant
I hope this helps.
Jorgela
12 Nov 2022 16:18
Exactly. The main reason is usually incorrect alignment. Simply check with a spirit level and adjust slightly. This often makes them much quieter.
bapar schrieb:
Treat the runners with PTFE dry lubricant
Very important! Do not use oil or grease, as this attracts dust and dirt.
If it is still noisy afterwards, you can also add small felt or rubber buffers. This effectively cushions the impact.
Davebla
13 Nov 2022 10:51
Matsli schrieb:
I am looking for effective ways to make the drawers quieter and to soften the closing overall.
I would like to point out that the issue does not always stem from the damping or slides themselves. Sometimes it’s the contents or the weight inside the drawer that affect the closing action.
If the drawer is loaded too heavily, the damping components no longer work optimally. Incorrect loading can also cause uneven weight distribution, which results in the drawer closing at an angle.
It is also often overlooked that dirt or slight misalignments on the runners can amplify existing noises. Especially with budget drawer slides, like those used in Ikea Metod, these parts are not extremely durable and can develop some play from frequent use.
Another consideration: How old are the drawer slides? Over time, the material wears down and the damping becomes less effective. If they have been in use for several years, replacing the slides or upgrading to higher-quality soft-close systems can be very helpful.
I would generally advise against improvised DIY fixes (such as makeshift dampers made from rubber or foam), as these can interfere with the mechanics or reduce functionality.
My recommendation: Check the slides, optimize the load distribution, and if necessary replace the slides. This approach is more sustainable than purely cosmetic solutions.
