ᐅ Enabling Soft Closing for IKEA Metod Drawers with Simple Modifications
Created on: 26 Jul 2021 14:07
ward42Hello everyone,
I have noticed that while the drawers in my IKEA Metod kitchen are sturdy, they unfortunately do not close smoothly, which can become somewhat bothersome with frequent use over time. My question is: Are there practical and preferably simple retrofit options or modifications to equip the Metod drawers with soft-close or dampened closing mechanisms? I am thinking of solutions that do not require completely replacing the drawers, such as additional dampers or upgraded drawer slides. It is important to me that the implementation is relatively straightforward and does not require extensive disassembly or special tools. Does anyone have experience or recommendations on how to modify the drawer mechanism in IKEA Metod kitchens? Thanks in advance!
Hello ward42,
well-formulated and very practical question! The topic of "soft closing" for IKEA Metod drawers can indeed be improved with a few targeted upgrades. Here’s a brief overview:
- First: The Metod series already comes with damped slides, but sometimes the damping is not sufficient, especially when fully loaded or with lower-priced models.
- Upgrades can be done, for example, by adding extra soft-close dampers, which are small hydraulic modules mounted on the drawers or the inner sides. A simple example would be external damping elements attached to the drawer frame or behind the front panel.
- Alternatively, you can switch to higher-quality metal slides with integrated soft-close function. However, these usually require removing the old slides and replacing them with the new ones — but it’s still an easy job with a cordless drill.
Common mistakes include buying dampers that are too large and do not fit the drawer size or installing the dampers upside down, which causes noise and poor function.
If you like, I can provide a short list of recommended products and installation tips. Otherwise, just let me know!
Hello ward42,
to address your question about easy retrofitting options in more detail, I want to go a bit deeper into the technical aspects.
The Metod drawers are based on well-known drawer slides from Blum or similar brands, which already provide some damping. However, this varies significantly depending on the model, load condition, and installation accuracy.
There are three main approaches for retrofitting:
- Replacing the standard slides with Blum soft-close slides (e.g., BLUMOTION). These are often plug-and-play compatible with Metod, but you need to remove all the rails and install the new ones. This upgrade worked best for me because the damping uses high-quality integrated hydraulics.
- Installing additional self-adhesive soft-close dampers (hydraulic cylinders): Here, you need to measure precisely where to mount the damper, usually at the back of the cabinet or drawer frame. Installation can be tricky because the position affects effectiveness and lifespan.
- Replacing the drawer slides with damped rails from other manufacturers that are compatible with Metod. There is a risk of fitment issues here.
It is important to note: soft closing can only be as smooth as the drawer’s running quality. If there is too much play, even the best damper won’t help much. So first make sure of precise adjustment and secure fixing.
A few questions:
- Are your Metod drawers currently equipped with soft-close slides or simple roller slides?
- How large and heavy are the drawers in your kitchen? Loaded or empty?
With these details, I can give you more precise recommendations.
A few questions:
bapar schrieb:
Soft-closing can only be as good as the smoothness of the drawer slide.Thank you for the detailed explanation! Currently, I have standard Method drawers with basic metal runners, but without an integrated soft-close function. The drawers are quite heavily loaded with cookware, which often causes loud and jerky closing.
My idea is to add extra damping without having to change the runners extensively. Therefore, self-adhesive soft-close dampers seem interesting to me, but your comments on the mounting positions sound important. Do you or anyone else have clear recommendations on how to attach them optimally and durably? I would also appreciate advice on the best brands or designs.
ward42 schrieb:
Therefore, self-adhesive soft-close dampers seem interesting to me, but your notes on the mounting positions sound important. Do you or anyone else have a clear recommendation on how to attach them optimally and durably?Adding to bapar’s input, I can share from my experience that the following approach usually works well:
- It is important to have a clean surface, so the area where the damper sticks must be free from dust and grease (best wiped with alcohol).
- Dampers are usually attached on the inside of the drawer back, centered or slightly offset to the side, so the damper is not stressed at an unfavorable angle when closing.
- It is very helpful to simulate how the damper compresses beforehand using a piece of cardboard or similar, then mark the ideal position.
- There are different designs: elongated dampers or shorter cylinders. For heavily loaded drawers, I prefer the longer hydraulic dampers as they provide more resistance.
Avoid cheap models that come with unsuitable adhesives, as these can slip off quickly. It’s better to invest a bit more for better adhesive performance.
If you want, I can send you some product names via private message that I have installed myself and that provide good hold.
