ᐅ Maintenance Agreement for Heating System with Air-to-Water Heat Pump
Created on: 5 Apr 2019 10:26
Malz1902
We have just received a quote from our plumber for the maintenance of the heating system.
The following services are included in the offer:
Inspection of the household water filter for proper function, including replacement of the filter cartridge
Maintenance of the small sewage lifting station, including cleaning if necessary
Maintenance of the air-to-water heat pump, consisting of:
Cleaning of the heat exchanger in the outdoor unit
Leak check on both the refrigerant and water sides
Function check of pumps, mixing valves, compressor, etc.
Operational testing of the control system
Inspection of the sacrificial anode in the domestic hot water tank
Inspection of the in-wall bathroom exhaust fan, including filter replacement
Net price: 262 €
What do you think of this?
Is it reasonable or not?
Are the costs appropriate or too high?
Net price: 262 €
Bieber08159 Apr 2019 22:25guckuck2 schrieb:
The polish for the outdoor unit I assume the heat exchanger is meant to be cleaned, meaning dust and other debris removed from the fins. I would definitely do that, preferably every autumn (before the heating season).
HilfeHilfe10 Apr 2019 07:34Bieber0815 schrieb:
I assume the heat exchanger needs to be cleaned, meaning dust and other debris removed from the fins. I would definitely have that done, preferably every autumn (before the heating season). Is it a problem if something is there?
Bieber0815 schrieb:
I assume the heat exchanger needs to be cleaned, meaning dust and other debris removed from the fins. I would definitely have that done, ideally every autumn (before the heating season).A visual inspection and a quick blow-through you can do yourself. If you don’t have an air compressor, you can buy canned compressed air for about 5€.
By the way, it’s worth checking the manufacturer’s maintenance instructions to see if cleaning is even necessary. After all, this unit is designed for outdoor use. Dusting it off is more like something you'd do for a display case.
Overall, these services often include about 50% travel or call-out charges. I wouldn’t opt for that.
So, we decided not to do that. I will change the filters myself. I just need to check which type of inline exhaust fan we have in the bathroom.
In the basement, the whole-house water filter is a Sanibel Comfor WFD. According to the instructions, the filter should be replaced every 6 months. Should we do that, or is once a year enough?
