ᐅ LW heat pump Alpha Innotec LWDV with 12 kW?
Created on: 24 Jan 2020 08:38
freisinger
Hello everyone, I am looking for an air-to-water heat pump with around 12 kW heating capacity that is also eligible for funding. I am confused about the LWDV 91-1/3 HDV 12 and HSDV 12 models from Alpha Innotec. Do they actually have a 12 kW heating capacity or not? They are basically the same as Novelan, and there is no clear information there either.
Are there any professionals in the forum who are familiar with this?
Good luck
Woogl
4 Feb 2020 19:34
freisinger schrieb:
So, the heating technician contacted me yesterday. He will not install the air-to-water heat pump because my heating load calculation is not realistic. His calculation with the high heat transfer coefficient (H'T-value) of 0.22 is realistic, and the 0.16 from the energy consultant is just theoretical. On the other hand, his domestic hot water heat pump is also not eligible for subsidies because the storage tank is poorly insulated. I give up.
Then he should install another subsidy-eligible domestic hot water storage tank....!!
He probably wants to install the 12 kW (12 kW) air source heat pump because he’s afraid the smaller one won’t be sufficient and you’ll come back to him for liability claims.
May I ask what kind of insulation your house has to justify the H'T-value of 0.16?
Woogl
4 Feb 2020 20:08
Additionally, the subsidy for the hot water storage tank is only 500€. It is a checkbox on the Bafa application called the "Efficiency Bonus." If the hot water storage tank is not efficient enough, there is still the basic subsidy of 4000€ for the water heat pump! Your heating engineer really has some shortcomings here!!!!
Also, I don’t understand why he simply doesn’t offer an eligible storage tank...?
freisinger
4 Feb 2020 20:30
Regarding the eligible heat storage tank:
it obviously needs to be compatible with the heat pump. He is not sure if it performs as well as the poorly insulated tank.
About the insulation:
it is basically a wooden house with 42cm (16.5 inches) walls (cellulose and wood fiberboard) and a ground slab with 18cm (7 inches) of insulation. Everything else is basically standard.
About the heating installer: I have no idea based on what criteria the calculations are made. I actually need to look for alternatives and I’m a layperson. Other heating specialists don’t even get back to me. Maybe I’m overcomplicating things.
If anyone knows a good and honest heating or plumbing professional in my area, please send me a private message.
Woogl
4 Feb 2020 21:34
Sh-Tec Schweitenkirchen, Schmidhuber Attenkirchen
How many liters of hot water should the storage tank have? The above-mentioned tank was recommended to me in the building technology forum because of its especially thick insulation and the very large internal heat exchanger surface area (better efficiency).
freisinger
4 Feb 2020 22:36
Currently, 300 liters (79 gallons) of domestic water and 200 liters (53 gallons) of buffer storage are offered. Efficiency class C.
@Woogl: Which storage tank do you mean?
Daniel-Sp
4 Feb 2020 23:30
What kind of buffer? How is it installed? Why use a buffer? You’re building with underfloor heating!
The storage capacity of 200 liters (53 gallons) of water compared to the storage capacity of the screed in such a large house is negligible.
If there’s no truly rational reason for the storage tank, just remove it!
Why does the heating technician simply use a heat transfer coefficient (HT) of 0.22 when the energy consultant calculated 0.16? That’s a significant difference.
This all calls for outsourcing the calculations or doing them yourself.
