Hello everyone, I have a Billy bookshelf with some joints where the glue has come undone. It is the typical particleboard with a white coated surface, and the edges are glued. My question is: What repair methods are available to reliably undo the loose glued joints on a Billy bookshelf in order to reglue them afterwards? I am especially interested in the procedure that does not unnecessarily damage the material or the surface. Do I need to apply heat, use special solvents, or proceed in another way? It would also be helpful to know the best way to remove old glue residues and which wood glue is recommended for reglueing. Thanks a lot for your tips!
The delamination in Billy shelves usually results from a plywood panel coated with melamine resin and bonded with white glue. To separate the glue without damaging the surface, strong heat and aggressive solvents should be avoided.
A proven method is to slightly moisten the affected areas, then gently pry them apart using a clamping tool, and mechanically remove the old glue residue with a fine scraper or sanding pad. Using wood glue (polyvinyl acetate) is recommended for re-gluing, as it is well compatible with the material.
If the bond is stubborn, carefully applying heat with a hairdryer on a low setting may help, but proceed with extreme caution to avoid damaging the coating. Solvents can attack the surface and should generally be avoided.
Regarding gluing Billy shelves, I would like to add that the particleboard panels with melamine coating are particularly sensitive to moisture. Therefore, dampening should be kept to an absolute minimum to avoid swelling of the panels.
That is a good tip. However, it is important not to set the temperature so high that the melamine surface discolors or warps.
If the glue joint is open, a gel or white wood glue based on PVAc (polyvinyl acetate) can provide the best adhesion. Apply evenly and clamp tightly with screw clamps. Let it rest for several hours—this is very important due to the low absorbency of the material.
Joshbe schrieb:
If the glue joint is stubborn, gently warming it with a hairdryer on a low setting might help
Santiagobu30 Aug 2016 10:45I would recommend that if the shelf is loose at important corner joints, first carefully warm these spots with a heat gun to slightly soften the old adhesive bond.
Then gently pry open the joint with a wooden spatula and carefully remove the old glue residues using fine sandpaper or sanding fleece. Be cautious not to sand too much, as this can damage the melamine surface.
For re-gluing, wood glues used for photovoltaic installations are suitable; there are also so-called "white glues" that dry clear. When clamping the pieces together, make sure to properly align the joint so the shelf does not end up crooked. A clamping time of at least twelve hours is recommended, preferably overnight.
I have personally repaired several Billy shelves successfully using this method.
