We have moved into our new build and noticed that it takes quite a long time for hot water to be available.
It feels like I use about 3 liters (1 US quart) and wait 30 seconds or more before the water starts to get warm.
We do not have a circulation pump, and this was not offered to us beforehand. Therefore, installing one now is not an option.
Our developer generally says that circulation pumps are not necessary in single-family homes.
What is your experience with this?
We have a circulation pump and are very satisfied with it. Our pump is off from 11:00 PM to 6:00 AM. Between 6:00 AM and 11:00 PM, it is on when someone is present (detected via smartphones connected to the Wi-Fi → controlled by KNX).
As a retrofitting option, I only see a small tankless water heater.
Possibly a bit off-topic:
Regarding the costs of circulation pumps, I have read that electricity is relatively cheap (assumed €12/year as mentioned by [USER=28865]@77.willo). However, the hidden costs seem to lie in the hot water preparation for this loop, which should be many times higher (depending on the system used). I hope the experts here in the forum can confirm or refute this?
Good luck
Good luck
Knallkörper8 Mar 2017 11:28ntsa86 schrieb:
I hope the experts here in the forum can confirm or debunk this?
Good luckI’m not an expert, but:
- The few meters of pipe probably release less energy through the insulation than an equally long section of the underfloor heating pipe, even if the latter is cooler. You might have around 25 meters (80 feet) of the main circulation pipe in the house, but the underfloor heating pipes are more likely to run hundreds of meters (feet).
- The energy stays inside the house, so it’s not necessarily lost (except in summer).
Well, I can’t imagine building without circulation either. We also have a dishwasher and washing machine connected to hot water, which alone made it worthwhile, not to mention the comfort when showering.
The correct point is that the circulation system also loses heat in the pipes. However, from the perspective of the building’s sealed envelope (house), the heat is not lost but may potentially warm other rooms as well (theoretically).
To put it briefly: cost-wise, it is more or less neutral with slight disadvantages. It is more a matter of comfort. In the end, the expense is not significantly high but does provide some benefit.
If the new building has just been approved, it is still possible to create a defect report based on the mentioned DIN/VDI standards and demand fulfillment. In our case, discussions had already taken place with the tilers from the sanitation contractor because they wanted to break up the entire hallway. The regulations are not there without reason. A delay of 25 seconds until warm water arrives is simply poor planning or execution and therefore a defect. Either the pipe was not installed as the planner calculated, the pipe diameter is too large, or the planning was already incorrect—in the best case, there was no planning of the hot water pipe at all.
Always remember: you are building a modern house and, for example, can never get warm water from the kitchen tap when you only need 2–3 liters (0.5–0.8 gallons) for the pot, but warm water only arrives after 4 liters (1 gallon) have run. That is completely ridiculous...
With minimized pipe lengths and optimal pipe diameters, a circulation pump is usually not necessary. Ideally, the bathrooms are located directly above the boiler room, so 5-6 meters (16-20 feet) of water piping is sufficient. Using the pipe diameter and flow rate, everyone can calculate how long they will have to wait for hot water.
