ᐅ Load-Bearing Capacity of L-Blocks and Water Drainage on a 45° Slope
Created on: 3 May 2022 15:39
Nixwill2
We are planning to build a retaining wall with 2-meter (6.5-foot) tall L-shaped concrete blocks on the south side of our property. To quickly raise the ground level from 300 meters (984 feet) to 305 meters (1,001 feet) above sea level (the development plan allows a 2-meter (6.5-foot) high retaining wall), we intend to add a slope on top of the wall.
I have attached a simple sketch. It shows a 2-meter (6.5-foot) high L-block at around 300 meters (984 feet) above sea level. To the right is a dashed line representing the house wall, roughly 3.5 meters (11.5 feet) away from the retaining wall. At the top right, the ground floor level of the single-family house is marked at 305 meters (1,001 feet) above sea level. The 45-degree line indicates the slope. I hope this helps to visualize the situation.
Diagonal beam from bottom left to top right (45°); floor plan with house wall on the right.
Now to my two questions.
We have had a few earthwork contractors inspect the site, and none of them saw any issues. Yesterday, however, I received a preliminary notice from the local building authority that a neighbor downhill has filed an objection. The objection is not against the wall itself but demands that the wall be constructed as a solid concrete structure for static (structural) reasons. Additionally, the neighbor insists that surface water from our property must not flow onto theirs. According to the authority, he cannot enforce the demand for a massive concrete wall, so that request was denied. I fully understand the water issue, which is why it will be part of my second question.
Since this neighbor, who appears to be a builder himself, is already questioning the structural stability, we should expect a thorough review of our wall’s engineering. Therefore, I want to be fully prepared.
As I said, the earthwork contractors see no problem with a 2-meter (6.5-foot) high L-block wall with a 45° slope behind it. What concerns me is that when I searched online, I couldn’t find any L-shaped concrete blocks 2 meters (6.5 feet) high that are certified for a slope steeper than 30 degrees behind them. Is there anyone here who can confirm that such blocks exist? I trust the contractors, but it’s important for me to have some documented proof if needed.
Moving on to question two.
This concerns the water that will certainly run over the remaining part of the wall during heavy rain because of the slope. In my sketch, I marked a dimension ‘X’ at the top end of the L-block. How far down do you think I have to go here to ensure that no water will overflow?
By the way, the scenario in the sketch represents the steepest point. The slope of the property and the wall actually run in the same direction, so in other areas, a much gentler slope will suffice, and I could even create a kind of drainage channel.
The plan is to cover the slope with ground cover plants and hopefully some bushes as well, if they take root. I will create a dedicated thread on this topic in due course.
Do a few plants on the slope provide enough resistance to prevent water from overflowing or at least significantly reduce flow velocity?
We intend to consult a professional landscaper about this issue after the house is built, but for budget reasons, this will have to wait.
I would appreciate any advice or experiences you can share...
X
x0rzx0rz
4 May 2022 11:28
@Nixwill2 Keep your head up and don’t lose hope. The excavator hasn’t arrived on site yet! It will work out!
As you already mentioned, contact the relevant authority to clarify their flexibility. Always emphasize safety concerns for yourself and your neighbors.
Try to talk to the other neighbors to find out how they solved this in the past or if they are currently facing any issues.
Please prioritize clarifying the drainage situation of your uphill neighbor (the authority may also provide information on this). A drainage system is a specially backfilled trench with a pipe that collects surface or hillside water and directs it through the pipe, ideally into a stormwater system. The goal is to keep water away from your basement/foundation, which is especially important on sloped sites.
Will your basement be constructed with waterproof concrete (called a “white tank”) or a so-called “black tank,” which means it only has external waterproofing?
haydee
4 May 2022 11:29
And no, you are not starting too early with the landscaping plans. Quite the opposite, you are actually starting too late. It’s not about planning where exactly each plant should go. You are planning major earthworks, and you are right—that should be addressed now.
The next person who rolls their eyes, just ask them how the excavator, building materials, and soil will be delivered and brought around to the back of the house later on.
This also applies to the rest of the construction. Trust your intuition.
Nixwill24 May 2022 13:23
x0rzx0rz schrieb:
@Nixwill2 Keep your chin up and don’t lose hope.
This is becoming increasingly difficult, I really can’t say it any other way...
Thank you all for your messages and advice!
Myrna_Loy
4 May 2022 13:41
It can also be very simple, though as armchair architects we can’t really judge that, but you have definitely got an idea to keep asking questions. Better to be startled now and then breathe a sigh of relief, than to stumble from one expensive special solution to another later on.
Tolentino4 May 2022 13:43
Have a maintenance shaft installed on your main sewer line somewhere (it costs a few hundred euros, but it’s worth it). Then, if you fill your cistern halfway through it once or twice a year, that counts as sewer maintenance or pipe flushing, and you’re done.
X
x0rzx0rz
4 May 2022 14:00
Tolentino schrieb:
Have a maintenance shaft installed somewhere on your real sewer line (it costs a few hundred euros, but it’s worth it). Then, if you let your cistern run half full into it once or twice a year, you call that sewer maintenance or pipe flushing, and that’s it.
If the authorities are really strict about it, they will probably require the cistern to have an infiltration system. And if you actually have to procure and install one (the wastewater association might also want to inspect it), then you might as well use it.
With those seemingly vigilant neighbors, this can quickly backfire. Then the house is built, and suddenly the excavator has to be flown in again by crane at short notice.
