ᐅ Sand-lime brick or autoclaved aerated concrete (AAC) blocks for house construction – how to decide?
Created on: 1 Dec 2020 11:58
Anna_BWHello dear forum,
We are now in the final stages of planning. The next step is choosing the building blocks. We are constructing a city villa with an attached bungalow. The plot is located next to a tram track (with a narrow street in a 30 km/h (about 20 mph) zone in between), and behind that there is a fairly busy road. A new school center is currently being built about 200 meters (220 yards) away as the crow flies.
The options are:
1. Ytong PP2 with a U-value of 0.23 W/m²K (0.04 Btu/(h·ft²·°F)) or
2. Sand-lime brick 17.5 cm (7 inches) with 1600 mm (63 inches) mineral external wall insulation system (EWIS)
The financial difference between the two systems is not decisive. I know there are strong opinions here about which system is best.
My main concern is noise insulation. I would consider myself sensitive to noise and am worried that choosing Ytong might turn out to be a mistake.
Are there any experiences? Decisions that were right? Decisions that were wrong? Or insights that could guide me in any direction? The choice of block will be a joint decision, although I am probably the only one leaning towards sand-lime brick because of noise protection.
Thank you very much!
Anna_BW
The options are:
Anna_BW
allstar831 Dec 2020 12:26Anna_BW schrieb:
The options are:
1. Ytong PP2 with a U-value of 0.23 W/m²K or
2. 17.5 cm (7 inches) calcium silicate block with 160 mm (6.3 inches) mineral-based external thermal insulation systemWhat is the wall thickness of the Ytong? You might lose a few square meters there, which could factor into the decision. We are building with aerated concrete and, for example, separate the granny flat using calcium silicate blocks.
Anna_BW schrieb:
The plot is located next to tram tracks (with a narrow street in between, speed limit 30 km/h (20 mph)), behind which is a fairly busy road, and a new school center is currently being built (approximately 200 meters (220 yards) as the crow flies).In that case, you should diffuse the noise before it reaches the wall, and in my opinion, the (already somewhat exaggerated) difference between sand-lime brick and aerated concrete is relatively insignificant.https://www.instagram.com/11antgmxde/
