ᐅ Plaster Application Marks with Q2 Finish Agreement
Created on: 19 Mar 2022 23:47
JohnBuilder
Our interior plasterer has completed the lime plaster (Weber174). On almost all walls, the marks from the finishing trowel, in the form of grooves and scratches, are clearly visible. We understood that lime plaster does not have a perfectly smooth surface, but we had expected at least no visible tool marks. The contractor was contracted for a Q2 finish, and we always emphasized that we want to paint the plaster directly. The contractor repeatedly assured us that the painter would fill the grooves by using a lambswool roller. However, the painter has now said that this will not work with the planned silicate paint.
The plaster has already dried quite a lot, and we are now looking for advice on how to further treat the walls to eliminate these marks.
JohnBuilder
21 Mar 2022 19:03
According to the contractor, the wall has been skim-coated. I expected the typical rough texture, but it is actually uniform, and you cannot see the individual steps of the skim-coating process.
This is how it currently looks on two walls:
Unfinished interior with shell walls, visible electrical outlets, and blue floor protection edging.
I will look for a close-up shot shortly.
JohnBuilder
21 Mar 2022 20:49
Here are some closer pictures:
Close-up of a beige carpet surface with fine pile and slight texture
Rough, light gray interior wall with plaster; window on the left, light spots from sunlight.
Unfinished renovation room with gray wall, open window, and view of a red house outside.
Rough, light gray concrete/plaster surface with irregular texture
HausiKlausi21 Mar 2022 21:17
I cannot comment on the requirements for surface imperfections regarding Q2, but to my knowledge, a Q2 plaster finish is always intended (and defined) as a base for textured wallpapers, structured coatings, brush-applied plasters, etc. From the photos, there seems to be little to criticize about the plasterer’s work here. “Regular paint” does not forgive imperfections and clearly shows the texture. I believe Q2 is the highest quality level achievable with lime plaster. Beyond that, filling and smoothing are necessary. In my opinion, he delivered exactly what was requested.
jcan
21 Mar 2022 21:41
With the lime system, you can achieve nicer surfaces; the material itself is not the issue. It’s just that Q2 finishing is required and contracted. A smoother, troweled surface would probably have to be applied in two layers. Using a 1mm (0.04 inch) grain size already allows for decent surfaces. However, that corresponds to Q3 and must be compensated accordingly.
Yaso2.021 Mar 2022 22:06
JohnBuilder schrieb:
Q2 was agreed with the contractor, with the understanding that we would paint the plaster directly.
We also pointed out that we wanted to paint directly, and our situation looks similar.
Our expert inspected the result and told us that the specified Q2 finish was achieved.
However, there seem to be homeowners with different expectations. He has also had clients who considered the result good enough and started painting almost immediately.
In our case, additional filling and sanding work is still required.
Friends and my husband have a knack for this, and the father of a close friend works professionally in this field and basically acts as a foreman for the whole team 🙂 Hopefully, this will achieve the originally desired result.
Tolentino21 Mar 2022 22:13
By the way, we had great success achieving smooth surfaces on the ground floor using heavy painter’s fleece. However, in hindsight, you would have spent a lot of money on lime plaster unnecessarily, as a simple gypsum plaster would probably have been sufficient.
