ᐅ Lighting and Electrical Planning in New Construction
Created on: 8 May 2021 08:10
Hendrik1980
Dear forum,
we are currently planning the construction of our single-family house. Last week, I created an initial draft for the lighting and electrical installation, which I would like to share here for discussion.
Do you think I should reduce the number of recessed ceiling lights? Are the power outlets sufficient? I look forward to your comments!
Floor plan ground floor: residential house K7 (Kley) with living, dining area, and kitchen.
Floor plan upper floor of a residential house K7 (Kley) with rooms, hallway, bathroom, and technical symbols.
Martial.white
8 May 2021 13:22
I am currently in the same phase. We removed many direct spotlights and will instead use wall-mounted fixtures for indirect lighting.
Don’t forget the mounting boxes for the Wi-Fi access points! The steel-reinforced concrete ceilings block the signal from the router.
Hendrik19808 May 2021 22:05
Martial.white schrieb:
I’m currently in the same stage. We removed a lot of direct spotlights and are going to install indirect lighting on the walls instead.
Don’t forget flush-mount boxes for the Wi-Fi access points! The concrete ceilings block the signal from the router.
How did you arrange the indirect lighting on the walls? I’ve also been thinking about flush-mount boxes. The router will probably go in the office (upper floor), so I’ll likely need an access point on the ground floor and on the terrace as well, right?
Gudeen.
8 May 2021 22:20
Forget the Wi-Fi integrated in the router and install an access point as centrally as possible on the ceiling in both the ground floor and upper floor (e.g., Ubiquiti or similar).
8 May 2021 22:27
.... usually one ceiling outlet per room is sufficient 🙄
Hendrik19808 May 2021 22:33
.... usually one ceiling outlet per room is enough 🙄
One access point per room??? Isn’t that over the top?
Yaso2.08 May 2021 22:43
A ceiling outlet is a connection point for a ceiling light, not for access points.
We have also omitted recessed spotlights throughout the entire house, except in the bathroom. For the kitchen, there will be surface-mounted spotlights; we planned the wiring (ceiling outlets) accordingly, as recommended by our kitchen planner for optimal lighting.
