ᐅ Lifespan of a Prefabricated House?
Created on: 22 Jan 2022 17:55
MeinHaus45
Hello!
I’m generally not a fan of prefabricated houses. However, I have been trying for a long time to find a suitable plot of land in my area. Now I’ve finally found one. Unfortunately, the land belongs to a prefab house supplier and can only be purchased with a building on it.
I’m not sure if the disadvantages of a prefab house are worth it. Unfortunately, I can only find very vague information online. It says that the lifespan of a timber-frame prefab house is between 45 and 100 years. Forty-five years seems really quite short. Is it possible to extend the lifespan of a prefab house through maintenance or renovation, or is demolition inevitable after 100 years at the latest?
blubbernase
23 Jan 2022 09:07
For about 10 years now, modern appraisers have not applied blanket devaluations for prefabricated houses. This means that in terms of service life, these solid houses are treated equally.
WilderSueden
23 Jan 2022 10:07
There was a recent Plusminus report about prefabricated houses. The tactic was explained as well. Not paying is not enough; you still have a construction contract with the company. It may not be legally sound, but you would have to go to court first. Until then, you don’t have a plot of land from them, but you do have a contract that allows them to use another plot you found yourself. You may have even already signed another construction contract for that...
Until the matter is resolved, you cannot make a reliable cost estimate and will face even more stress than usual during the housebuilding process. Therefore, make sure to obtain proof that they actually own the land; otherwise, don’t engage in any discussions. Also, the building contract needs a clause stating that it becomes void without compensation if the land is not sold to you. If Massa Haus does not agree to this, then you know where you stand.
Pinkiponk
23 Jan 2022 10:22
MeinHaus45 schrieb:
According to the offer, the land is included. This will, of course, also be regulated contractually.
If you have the time and interest, please research in the press and on the municipality’s websites whether the land really belongs to "xyz" or if they are just attaching themselves to plots already offered by others. Home builders usually do this, and from my experience (about 2 years ago), "xyz" is no exception. Please be extremely cautious in this regard; I cannot be more explicit for legal reasons.
Also, please have the home construction contract reviewed by a professional before you sign it. These combinations contain many potential pitfalls.
driver55
23 Jan 2022 10:57
MeinHaus45 schrieb:
I’m not sure if the disadvantages of a prefabricated house are worth it.
Please list the disadvantages, or the pros and cons of prefab versus traditional solid construction, before my timber frame cabin falls apart over my head.
However, the combination of the plot and the house provider is probably more worth discussing here.
FoxMulder24
24 Jan 2022 10:14
Besides all the issues related to the plot.
Just like with general contractors (GCs) for solid houses, there are significant quality differences among GCs for prefabricated houses.
We built with a local prefab house provider (about 1 year ago) and are satisfied so far.
However, it can be different with company "xyz". My brother-in-law built with them around the same time as us. The experiences there are completely different compared to ours.
Durran
24 Jan 2022 12:13
maulwurf79 schrieb:
In northern Hesse, we have half-timbered houses that are 400 years old or more. They were often built without proper foundations, without protection against rising damp, and using very basic construction methods.
Modern timber frame houses, when well built, are superior to simple brick houses in almost every way. The only exceptions are thermal mass and ceiling sound insulation, where brick houses perform better.
However, to match the energy efficiency of a timber frame house, a solid masonry building requires significant effort and thick walls.
You can’t really compare houses that are hundreds of years old. Those buildings were and are naturally well ventilated, have a natural moisture regulation, and were designed with building physics in mind. Today, it’s rarely possible to achieve that.
Materials like drywall, OSB boards, mineral wool, and expanded polystyrene didn’t exist back then. The foundations made of rubble stone had no moisture barriers or vapor retarders—which were also not needed at that time.
However, even the smallest construction error in a prefabricated house can later cause severe damage to the building structure. And it is very rare to be able to verify whether the Polish subcontractors did everything correctly during the assembly. Of course, the local skilled workers are not much easier to monitor either.
A solidly built masonry house is much more forgiving in that regard.
If you ever experience water damage in a prefab house caused by backed-up sewage water, a clogged drain pipe, or a burst water line, you’ll quickly become aware of this disadvantage.
