ᐅ Getting Ikea Metod Drawers to Close Softly and Quietly Without Much Effort
Created on: 23 Sep 2020 09:47
GAULAU
GAULAU
23 Sep 2020 09:47
Hello everyone, I have a question about Ikea Metod drawers and their closing mechanism. I have installed several Metod base cabinets with drawers, but I am not happy with the drawers because they close quite loudly and harshly without any soft-closing feature. I am looking for ways to make the drawers close smoothly and quietly—preferably without much effort or having to remove the entire drawer. Are there simple modifications that can be made to improve the closing action? Maybe some compatible attachments or modules that can be retrofitted? I would appreciate concrete tips or experiences, especially regarding reliability and practical use. Thanks in advance!
bupar
23 Sep 2020 12:13
The Ikea Metod drawers can be made to close much more smoothly and quietly by installing so-called "soft-close" dampers. There are several options for this: - Original replacement parts from Ikea: Some Metod drawers already come with soft-close features, or retrofit kits are available that can be installed directly. Installation is often tool-free or only requires removing the drawer front and a simple clip attachment. - Universal soft-close adapters: Generic dampers are available at hardware stores or home improvement centers that can be mounted between the drawer and the cabinet. These dampers cushion the impact and reduce noise. - Maintenance and adjustment: Lack of lubrication or incorrectly adjusted drawer slides can increase noise. Regular cleaning and light silicone spray can improve smoothness. A complete drawer removal is usually not necessary; small adjustments are often sufficient. It is important that the drawer runner remains compatible. For a quick retrofit, original Ikea accessories or suitable dampers tailored to Metod profiles are recommended. The reliability of these retrofit solutions is generally high as long as proven products are used.
Linavin
23 Sep 2020 15:06
bupar schrieb:
Original spare parts from Ikea: Some Metod drawers already come with soft-close mechanisms, or there are retrofit kits that can be installed directly.
I am a bit skeptical about this because older Metod models often didn’t include soft-close as a standard feature, and the retrofit kits are not always fully compatible with all drawer variants. I also wonder whether the universal soft-close adapters really do not affect the drawer mechanics, especially for drawers that carry heavier loads. Has anyone had concrete long-term experience with them? Unfortunately, there are reports that some adapters can be prone to issues or reduce smoothness in operation if they do not fit perfectly.
LANICOLE
24 Sep 2020 08:22
To make this topic more practical, here is a brief guide on how to close Ikea Metod drawers smoothly and quietly without much effort:
1. First, check the drawer slides: Carefully remove the drawer and thoroughly clean the rails. Dust or dirt often accumulates, which can obstruct the closing mechanism.
2. Lubrication is key: Use a silicone-based lubricant that doesn’t become sticky or attract dust. Avoid oil-based lubricants or grease, as these tend to gather dirt.
3. Retrofit kits from Ikea or reputable third-party suppliers: These can usually be easily mounted on the sides of the drawer. Installation is often done with clips or screws, so no major disassembly is needed.
4. Check the cabinet and drawer front: Drawers often close loudly because the front panel is misaligned. You can adjust the front using a screwdriver to ensure the closing angle fits properly.
5. For models without soft-close: Mechanical dampers can be retrofitted. The key is to ensure compatibility with the existing slides and drawer profiles.
Summary: Cleaning, lubrication, and the targeted installation of suitable dampers are the most practical ways to make Metod drawers close smoothly and quietly—without major disassembly or remodeling. This keeps effort minimal and results optimal.
JAMESONB41
24 Sep 2020 18:44
Soft-close retrofit kits from Ikea are the easiest to install. Alternatively, lubricate the runners and adjust the front panel. Done.
Linavin
25 Sep 2020 10:58
That is not entirely true in general. In my project, I found that the durability and fit of these retrofit kits can vary. It is worth checking carefully in advance which models are truly compatible. Also, not every cabinet model from Metod is identical; there are sometimes differences in the drawer slides. Simply lubricating the glides often does not fully solve issues with hard closing impacts – the damper needs to be installed for that. Adjusting the front is certainly helpful but does not replace damping.
