Hello from the north,
we have been offered a quite interesting plot of land. The seller demolished an old house on this property but left the basement floor slab at a depth of about 3 meters (10 feet).
We do not want to build with a basement. Will this floor slab cause any problems for us? Does the old slab need to be removed? Should we possibly consider a special foundation?
Thank you very much in advance for your answers.
Henrik
Henrik
I would check this with the house construction company. It might depend on how the concrete slab is designed.
In some areas, we built over the walls of the old slurry pit. About 50cm (20 inches) of recycled material was placed on top, followed by the construction of the concrete slab.
HenrikM schrieb:
The seller demolished an old house on this plot but left the basement slab at a depth of about 3 m (10 feet).
We do not want to build with a basement. Will this slab cause any problems for us? Does the old slab need to be removed? Do we possibly need to consider a special foundation? So the basement slab is now below ground level, and the area above it has been backfilled? – try sketching this out: the outline of the planned house, the basement slab, and the excavation pit from the demolition. In principle, this doesn’t sound immediately concerning, but the information is still a bit limited. Does the seller have any photos from the demolition that he can share with you?
Who even does this and why – for example, did his children plan to build there but then gave up (because the desired house design wasn’t possible or something like that)?
