ᐅ Installing pavers with a 2 cm gap, similar to grass joint paving?
Created on: 23 Aug 2024 10:20
darksun
we would like to pave our entrance area with paving stones (or have it paved). These are not so-called lawn joint pavers. However, we would still prefer wider joints to sow a special grass mixture in the gaps and allow it to grow.
Lawn joint pavers come from the factory with built-in spacers corresponding to the joint width. Is it possible to install regular paving stones (according to the manufacturer, fill joint material of 1–3 mm (0.04–0.12 inches)) on a gravel base in a way that the stones are stable but still have uniform 2 cm (0.8 inch) joints? Are there spacers available, similar to those used for floor or wall tiles, that can be used as a guide?
This is how it should look in the end, see picture / or this is how it looks when the stones are laid "normally".
Grünes Moos wächst zwischen quadratischen Pflastersteinen eines Gehwegs.
Dachfläche mit grauen rechteckigen Dachschindeln in Schuppenoptik
Pat Rick18 Nov 2024 16:03
darksun schrieb:
Has anyone had experience with greening joints? Does it work as hoped?
For those facing the same question: On my uncovered parking space, I have grass pavers with about a 2 cm (1 inch) joint, and starting in spring, nature takes over. Weeds, moss, dandelions – they grow like crazy. It doesn't matter whether the joints are filled with gravel or soil. Since mine are currently filled with soil, pressure washing is not an option. I tried it, and it just turned into a muddy mess. The pavers weather over time and simply start to look unkempt.
