I more or less stumbled upon a plot of land after someone let their reservation expire.
The plot is about 606 square meters (6,521 square feet), according to my "measurement" approximately 18.10 meters by 33.50 meters (60 feet by 110 feet), not officially surveyed yet, and now I’m wondering exactly what I can do with it.
The development plan sets out the following for "my plot":
Here I have placed an example house measuring 9.60 meters by 11.95 meters (31.5 feet by 39 feet), which I like based on my initial review (Viebrockhaus Edition 600).
Next to the house, in the 5.50-meter (18 feet) wide space there would be a carport – is that enough space for two parking spots? I would prefer not to make the house narrower just to accommodate vehicles... but then there’s hardly any room left for fencing?!
The terrace and garden at the back are, of course, limited by the tall trees – but that’s a compromise I’ll have to accept.
I’ve never built a house in my life before... so this is my first time dealing with this topic in detail. What would you do in this situation? Make the house a bit smaller?
If you need more information, just ask – as I said, I’m a beginner and eager to learn 🙂
My wishes are:
- Starting from 160 square meters (1,722 square feet) upwards
- I’m currently thinking about a basement and budget around $100k extra for it
- I don’t like long corridors
Once the plot situation is reasonably clear, I’d like to hear your advice on floor plans – that will surely be a more extensive topic.
- 0.35 floor area ratio
- Single-story buildings only
- Maximum building height 10 meters (33 feet)
- Eave height max 4.50 meters (15 feet)
- One driveway with max width of 4 meters (13 feet)
- Two parking spaces are mandatory
- Roof pitch between 15° and 51°
- Roofs of garages etc. may differ in shape
- Garages, carports, and ancillary buildings as defined by §14 (1) of the building use ordinance, which are buildings, must not exceed the street-side building boundaries of the access roads.
- Dormers and roof recesses: the total length of dormers or roof recesses per roof side may not exceed 50% of the total length of that roof side.
- Standard distance to property boundary is 3 meters (10 feet)
- In the southern area, there is an 8-meter (26 feet) deep strip across the full width of the plot (approx. 18 meters (60 feet)) where trees and shrubs must be preserved. This area is quite densely vegetated and reaches heights up to 10 meters (33 feet) – I’ve tried to visualize this below
- In the middle of this vegetation is a downward slope... the building boundary to this strip was reduced from the normal 3 meters to 2 meters (7 feet) so the plots aren’t too restricted.
My wishes are:
hanghaus20008 May 2021 18:48ypg schrieb:
Oh yes, your plan has south oriented at the top 😉
I see it differently. The plan even includes a north arrow.SaschaL schrieb:
Which other reputed high-quality general contractors (GCs) do you know that build in Mecklenburg-Western Pomerania (specifically in the western area near the border with Schleswig-Holstein)?
- ecoHaus
- Team Massivhaus (around here in the region, it has a reputation for being low-cost—is that true?)
- Virtus Massivhaus
- Kern-Haus doesn’t seem to build in MV? Are there really strict regional limits? The construction site is very close to Schleswig-Holstein… I will inquire there.
Do you have any other recommended options? You can already find discussions about Eco, Team Massivhaus, and Virtus in the experiences-with-building-companies section (some multiple times). Kern is from the Westerwald region; I would only consider building with them in Rhineland-Palatinate, North Rhine-Westphalia, or Hesse.
haydee schrieb:
Albert Haus
Wolf Haus
Schwörerhaus
Rensch-Haus
Wir Leben Haus
Bien-Zenker See above—these are not providers from the NDR broadcast area ;-)
haydee schrieb:
@11ant
Building throughout Germany.SaschaL schrieb:
I’m also kind of confused… with most providers, I can’t even find information on their website about where they build…You’re only confused because you don’t understand the hint: if the provider doesn’t clearly state where they build, it probably means they operate nationwide—and that doesn’t necessarily mean they are unreliable, but for me, such a provider would always be a second choice. A reputable general contractor earns their good reputation locally, around their flagship projects.https://www.instagram.com/11antgmxde/
