ᐅ Laminate flooring installation cost including floor sanding, leveling, and laying
Created on: 19 Nov 2018 11:41
Sascha95
Sascha95
19 Nov 2018 11:41
I would like to get your opinion.
I have 70 sqm (753 sq ft) to cover in four rooms and a hallway. I have already purchased laminate flooring and baseboards.
I have now received a quote of 2000 EUR for the following work, including materials:
1. Sanding the floor because there are still adhesive residues (carpet/tiles) on it.
2. Leveling the floor with self-leveling compound.
3. Installing an underlay.
4. Installing the laminate flooring.
5. Attaching the baseboards.
Is this price excessive, reasonable, or normal?
Thanks in advance.
Sascha
blaupuma19 Nov 2018 12:54
Expensive.
If you buy laminate in a laminate house, installation often only costs 10 euros per m² (10.8 sq ft).
You have more work to do, but not such a big price difference.
19 Nov 2018 14:01
blaupuma schrieb:
Expensive.
If you buy laminate flooring in a laminate house, installation often costs only 10 euros per m2 (about $10 per sq ft).
In your case, there is more work to do, but the price difference shouldn't be that big.
But only on a finished substrate.
Removing adhesive residue is a real pain. Smoothing it out evenly certainly takes more than half an hour.
sco0ter
17 Dec 2018 09:20
We received an offer of 15 EUR per sqm on prepared ground. Although this was for prefabricated parquet, it probably doesn't make a difference.
Baseboard 4 EUR per meter.
Nordlys
17 Dec 2018 09:48
28.50 per sqm (square meter). Does this include the leveling compound, the machine, and the insulation mat? It is still a very reasonable price for the contractor. What is the market situation? Do you have any alternatives? K.
O
Obstlerbaum
17 Dec 2018 13:22
Solid surcharge for external materials. Get additional quotes, but it probably won’t be significantly cheaper...
