ᐅ Laminate Flooring vs. Luxury Vinyl Flooring in an Energy-Efficient House 40
Created on: 7 Mar 2026 23:45
Boden321
We are currently building an energy-efficient house with underfloor heating and are unsure about which type of flooring to choose.
We initially ruled out hardwood flooring. Floating engineered hardwood was not recommended to us, and high-quality glued hardwood would be very expensive for our approximately 150 square meters (1,615 square feet) of living space. Additionally, since we have two children, we want a floor that is as low-maintenance and durable as possible.
Therefore, we are currently considering high-quality laminate flooring (e.g., Logoclic Ambienta), which the manufacturer claims to be very quiet and environmentally friendly. Because we have children, it is especially important to us that the floor does not contain plastic materials or harmful substances such as PVC or plasticizers.
During our research, we also came across luxury vinyl tiles/planks (LVT/LVP) that are offered without PVC and plasticizers. Compared to laminate, these floors seem to have some advantages: they are said to be quieter, more water-resistant, feel warmer underfoot, and, in some cases, work better with underfloor heating.
At first glance, these advantages seem to outweigh those of laminate. Therefore, we are wondering whether we should reconsider our decision to choose laminate and instead opt for luxury vinyl flooring. In both cases, we plan to install the flooring as a floating floor.
Could you tell us what advantages laminate would have over luxury vinyl flooring in our situation – apart from the fact that laminate does not contain plastic and is considered more environmentally friendly?
nordanney
12 Mar 2026 11:41
Boden321 schrieb:
If I want to install both as floating floors myself, is hardwood flooring more complicated than laminate?
No. Exactly the same. Both are click-lock systems, both best cut with a miter saw plus a jigsaw.
Boden321 schrieb:
And what is the difference between lacquer-sealed and lacquered hardwood flooring?
Hardly any. Lacquered simply means coated with lacquer, whereas lacquer-sealed is more complex (multiple lacquer layers, all pores sealed, more durable). Some manufacturers may even use both terms interchangeably, but I wouldn’t judge that without explanation from the specific producer—Parador, for example, applies multiple lacquer layers even on their entry-level “Basic” range.
Keep in mind, however, that scratches cannot be easily polished out or refreshed with oil afterward.
motorradsilke
12 Mar 2026 14:43
Boden321 schrieb:
If I want to install both types as a floating floor myself, is parquet more complicated than laminate?
No, the effort involved is basically the same.
Boden321
12 Mar 2026 23:16
If the effort involved is the same, then the only question is whether the heating energy from underfloor heating passes through floating parquet flooring as effectively as it does through floating laminate flooring. What would you say?
13 Mar 2026 00:13
I’m following the discussion but prefer to withhold my opinions.
However, a quick note: my husband once installed inexpensive bamboo flooring himself. He’s not exactly handy, but he’s not easily “taught” in this area either. Still, it turned out very well.
The warmth is almost negligible. We have tiles elsewhere, and our office with wood flooring currently feels warmer underfoot than the tiles. When the heating is working hard during freezing temperatures, both surfaces feel about the same temperature.
If a floor covering is rated as suitable for underfloor heating, then it truly is suitable, meaning enough heat will pass through.
This early debate reminds me of discussions from the early 2000s. Wood was considered bad, but if you added the word “design” to plastic, it suddenly became the revolutionary choice.
nordanney
13 Mar 2026 07:50
Boden321 schrieb:
What would you say?
It is possible to calculate exactly how much worse a floating floor installation performs.
However, for the choice between glued down and floating, this difference is not significant enough to be relevant.
Boden321
14 Mar 2026 15:59
You were right. The difference is about 15-20€ per year. Is it true that with floating parquet flooring, I cannot install it continuously from room to room and have to use transition profiles?
