ᐅ Recommendation for a KNX Smart Home Video Intercom System – Single-Family Home
Created on: 25 Aug 2021 08:55
Antonio2908A
Antonio290825 Aug 2021 08:55Hello everyone,
I am currently considering the intercom system for our house planning.
Friends have recommended the Doorbird D2101V so far. (Price/performance is okay, although the camera quality is not outstanding.)
Do you have any good alternatives that you could suggest?
General information:
- The house will be wired with KNX
- The fingerprint scanner is already integrated directly into the door
Many thanks!
Many thanks!
Hello Antonio,
Unfortunately, I can’t say much about KNX and fingerprint systems or their integration with an intercom system, but I recently decided on the Metzler VDM10.
I also considered the Doorbird, but found the Metzler more visually appealing and it is significantly more affordable while offering similarly good technical features like viewing angle, etc.
Antonio290825 Aug 2021 10:43netuser schrieb:
Hello Antonio,
Unfortunately, I can’t say much about KNX and fingerprint systems or how they work together with an intercom, but I recently decided on the Metzler VDM10.
I also considered the Doorbird, but I found the Metzler more visually appealing and it is significantly more affordable while offering similarly good technical features such as viewing angle, etc.I’ve taken a look at it. It definitely looks good aesthetically 🙂 It’s definitely going on my shortlist! Thanks!
Antonio290825 Aug 2021 10:52netuser schrieb:
Hello Antonio,
I can’t say much about KNX and fingerprint systems or how they interact with door intercoms, but I recently decided on the Metzler VDM10.
I also considered the Doorbird, but I found the Metzler more visually appealing and significantly more affordable, with similarly good technical features like viewing angle and so on.Do you also have the indoor unit for it? I generally plan to mount an iPad on the wall to, among other things, operate the door.
Antonio2908 schrieb:
Do you also have the indoor station with it?
My plan is generally to mount an iPad on the wall and use it, among other things, to control the door. Yes, I initially bought the set with an indoor station. Additional units can be added later for 120–150 EUR.
So far, I don’t have much practical experience, but hopefully more soon.
I am also an iOS user and interested in hearing about experiences with the iPhone/iPad in this context.
At the moment, I can’t say much... in principle, everything should work.
Intercom systems and KNX typically only directly affect each other when you want to fully integrate the intercom into your visualization system. Is something like that planned? For example, Gira Home Server works best with Gira devices, Jung expert systems integrate well with Siedle, Basalte runs smoothly with Siedle and 2N, and free visualization tools list compatible intercom systems on their websites (make sure video functionality is supported!). If you also want to receive calls on the go through your visualization app, the setup becomes more complex.
Otherwise, you could use the intercom independently and capture the doorbell signal (for additional actions) and the door opener signal via their relay, e.g., through a binary input, to then open the door via KNX (never connect the door directly to the intercom station next to it!).
Recently, I installed several Doorbird 2101 units, which went quite smoothly, including integration with Control4 for these clients. Otherwise, I am a big fan of 2N.
