Hello everyone.
How high does a knee wall need to be at minimum to install standard windows on the eaves side of the upper floor (gable roof)?
Thank you in advance.
Sebastian797 Sep 2015 13:38To install "standard" windows, you probably need a second full story – anything less is not a solution, but rather a condition.
Otherwise, you’ll be looking at the roof all the time or, when standing, won’t be able to look straight through the window.
Watcher787 Sep 2015 13:52Thank you for the responses.
What would a cross gable cost for you, @Bauexperte, that creates two adjacent rooms, each with a floor-to-ceiling window? Without the cross gable extending into the ground floor. Something like in the attached picture. I’m wondering which option is more cost-effective: building two full stories (which is allowed) or adding a cross gable.
Bauexperte7 Sep 2015 13:59A dormer with a gable roof is created when the masonry is extended into the attic space, as shown in the illustration.
The illustration shows a flat-roof dormer – we would construct it differently on the side – I can only estimate the width of the floor-to-ceiling elements; a typical width would be 1.01 m (3.3 ft) plus the masonry between the windows, so the total width of the dormer is roughly around 3.50 m (11.5 ft). I believe that, even if transom windows are installed instead of French balconies, you should expect costs of at least about 5,000 EUR.
Edit: sorry – Paderborn is somewhat cheaper; let’s say starting at around 4,500 EUR.
Best regards, Bauexperte
Watcher787 Sep 2015 14:07Ok, thanks for your assessment... well, we’ll see if Paderborn is cheaper. I have to wait and see what my general contractor says, but unfortunately he is on vacation this week and I can’t request any prices.
What happens if a eaves height of 3m (at a split-level house on a slope) results in a knee wall height of 1.67m (5 feet 6 inches)? This is too low for standard windows but actually too high for roof windows to look out of. How can you cleverly argue with the building authority / planning office to get approval for a higher eaves height (knee wall)?
Bauexperte7 Sep 2015 14:54bortel schrieb:
How can one cleverly argue with the building authority to get a higher eaves height (knee wall)? Usually: not at all, if it is a development plan area. In that case, you have a better chance in a §34 area.
