ᐅ Knee Wall in a Danwood House in Schleswig-Holstein – What Are the Maximum Possible Dimensions?
Created on: 20 Apr 2018 00:01
Ap0rnym
I have a fairly simple question.
I want to build the 169A house from Danwood in Schleswig-Holstein. I would like to have the knee wall as high as possible (the catalog specifies it as 2 m (6 ft 7 in), but that apparently doesn’t work).
There are only two restrictions in the building area:
1. It must be a single-story building.
2. The ridge height must not exceed 9.5 m (31 ft 2 in).
I have already given it some thought and documented it in an Excel file. I would appreciate it if someone could tell me whether everything is correct or just generally advise how high the knee wall can be built given the dimensions of the house and the regulations in Schleswig-Holstein.
Thanks a lot!
Chris
Thanks a lot!
Chris
Ap0rnym schrieb:
now I just need to know the maximum height allowed for the knee wall. I couldn’t find any restrictions on this. Accordingly, the knee wall height would only be limited by the ridge height.
Let’s assume the following values: raw floor level on the ground floor (GF) at "0.00", floor-to-ceiling height on GF 285 cm (112 inches), floor construction thickness on the upper floor (UF) 16 cm (6 inches) (from which I assume you want to measure the knee wall height), so the finished floor level on the UF is at "3.01" meters (9.88 feet).
If we add your desired knee wall height of 2.00 m (6.56 feet) on top, the total is "5.01" meters (16.44 feet). With a roof pitch of 46° you’d still be within the allowed ridge height of "9.395" meters (30.82 feet). In practice, you will be well below that because you’ll still have the full story right below.
Conclusion: Relax. The regulations for avoiding a full additional story set tighter limits here than the absolute height. For example, with roof pitches of 22° / 25° / 28°, at 2.00 m (6.56 feet) knee wall height you’d reach a room height of 2.30 m (7.55 feet) after only 74 cm (29 inches) / 64 cm (25 inches) / 56 cm (22 inches) distance from the eaves wall—so much too soon. I therefore see, for example, a knee wall height of 1.80 m (5.91 feet) at 25° pitch as a better candidate for your calculations.
But you must not forget one thing. This zoning plan (B Plan) method of referencing heights to standard sea level (NN) prevents you from exceeding the 9.50 meter (31 feet) ridge height by adding fill and thus raising the house’s elevation. If you add 1 meter (3 feet) of fill, you only have 8.5 meters (28 feet) left for the building height. Clear? Karsten
That sounds logical. However, I don’t understand the first calculation from 11ant. In Schleswig-Holstein, the state building code states that the upper floor is considered a full story if it covers at least 75% of the floor area of the story below (and this is based on a height of 2.3 m (7.5 ft) from the floor to the outer roof surface). That’s why a 2-meter (6.6 ft) knee wall is impossible, right? So the Danwood 169A house specifies a 2 m (6.6 ft) knee wall, but that won’t comply, or am I mistaken? In this building area, it seems that the limitation is not the ridge height but the single-story design.
Yes, if I understand correctly, I see the problem as well. What does Danwood say? What would be an alternative? Does it have to be Danwood? If you want timber construction instead of solid wood, take a look at contract vario Ahrensbök near Lübeck. They are smaller, much smaller than Danwood, but they build attractive, very individual houses and are also affordable. K.
